Custom Glass Carbon Fibre R33 Projector Headlights Group Buy!
haha settle down Philby! they only bump em up to around 85volts
That is what they continously run at once they are operating. Pretty sure on initial ignition it bumps up to around 18-24kV.
Edited by PM-R33
is there going to be just a glass lens option available? i dont want to wreck the party but people who have a car worth 8-15k i dont think will be particularly willing to spend 2000-3000 on headlights. i know the HID option will look great and i dont want to criticise you efforts but i think a simple 'glass lense replacement' option using the remainder of the facotry headlight would probably suit the budget of more people on here. maybe add it as an option if it hasnt already been?
i think this is a great idea btw and im interested in the price for a glass lense as i will need a set for my gtr.
Yes the glass lens replacement will most likely be an option. Also the headlights will be under $2000. Honestly I realise it aint for every one, but for certain people that can afford it and want something different it's a great option and i'm really looking forward to it. The amount of money my car (and a lot of others) are worth once you add up every modification, another $2000 really aint the end of the world for something that is a worlds first and will update the look of the car.
oh please dont mention those words 'adding up cost' thats just too scary to think about...
Bring on the new headlights...
Hahahaha so true. To this day I regret keeping an excel spreadsheet of all the costs the car owes me.
I sent Spinto an email to see if there has been any progress; stay tuned.
sounds good, look forward to the final result
UPDATE
Spinto is receiving the projectors in the following week so will start creating the carbon fibre bezels to hold the projector in place. They also want to start making the tooling in the following week for the glass lenses.
They are also experimenting with making the carbon fibre frames for the lenses to try and make it an easy conversion.
Edited by PM-R33
I don't think this question has been asked. Will the lenses they make for the carbon fibre set up fit our existing lights or will they only fit their own design. I'm sure there'll be plenty of people after lenses only. If they're not the same as our original lenses can they make a glass replacement. Either way, can we get a price on replacement lenses for the factory light assembly.
I think you have confused yourself a little bit.
Our headlights and these new headlights are the same light assembly.
Ie. You send them your headlights, they pull off the plastic lenses, remove the low beam reflectors, remove the parkers and remove the black surrounds that hold/cover everything on the inside.
Now you are left with the plastic housing that mounts onto your car and the factory high beam reflector mounted inside. Into this the projector is mounted, the new LED parkers are mounted, the new carbon fibre surrounds are mounted and then the glass is fixed onto it sealing it together.
Hope that clears it up a bit.
There is no pricing at the moment, but judging by the price of the Supra glass lenses it would be a safe bet to say the glass lenses would be between $500-$1000, but that is purely my guess.
Edited by PM-R33
  • 3 weeks later...
I'll give the boys an e-mail later on tonight. I don't like to bother them to often as I know it is a long process and there is a lot to be done.
Guest
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
