hey guys my gf got a 34 with tiptronic auto. just wondering if anyone has had a shift kit put in thiers?? if so who did it, how much was it n did u get much improvement from it in fuel economy or performance n is it worth doing. just askin coz the stock auto feels a bit sloppy. in the mean time im gonna get the oil flushed n see if its any better.
I got what you might call maybe a "Stage 1" shift kit in my wagon (same gearbox but with a transfer case on the back).
Basically I took it to this guy in Bibra Lake who talked it up and then it turned out he hadn't seen one of these boxes before. So not knowing what galleries did what (there's more solenoids and valves than a 33 box) he did what he could, which was remove the accumulator plungers on the 1-2 and 2-3 shifts, and replaced them with welsh plugs.
It's made a huge difference, mostly on the 1-2 shift, I used to have to shift either early or bounce it off the limiter otherwise it would just slip (incidentally, even with all the slippage, he said the inside of the box was squeaky clean).
He didn't charge me much as we didn't achieve what we set out to achieve but to be honest, I'm not sure I would want any firmer shifts in my daily.. the place is called Global Automatics in Bibra Lake.
so it doesnt slip as much anymore while its in gear? n how harsh r the changes? like wheel chirping when it changes? did it improve fuel economy? also does the gear changing rpm change or is that to do with the computer?
It never slipped while in gear, there was just a massive flare from 1st to 2nd if the engine was making heaps of torque.. i.e. if it was on boost over 4000rpm it wouldn't want to go in to gear unless I backed off the gas or let it bounce the limiter once. Now it just gets the fuck in there!
Shifting is more positive and it would probably chirp 2nd if I didn't have 4WD. Put it in 2WD and it's highly amusing in the wet, as soon as it comes on boost, click 2nd and it shifts instantly then it's lunchbox super happy fun sideways time.
The 1-2 shift is harsher at slow speeds and I had to relearn how to drive.. I used to lift the gas on the 1-2 shift but if I do that now I nearly hit the car in front as it lurches hard.
It's not as full on harsh as say an MV Auto shift kit where the valvebody galleries are modified, but it's a very positive shift, no fucking around.
I would say it has improved economy somewhat but more importantly, it improved drivability tremendously!
Oh and when in tiptronic, the downshift to 2nd is INSTANT.
Edit: shifts may be nicer if you have stock ECU.. I have a Haltech that doesn't talk to the TCM so the ECU doesn't cut ignition when it comes time to shift, I also think that is why mine had so much trouble trying to shift into 2nd.
Edited by bubba
i just recently put shift kit in my 34 4 door. purchased the valve-body kit and the shift solenoid from M.V Automatics.
got it installed at Wangara Auto's.
its like driving a different car. gear changes are instant. 1st - 2nd can be a bit harsh but you learn how to drive it nicely.
the car will light up the rears going from 1st - 2nd now... :-) (of course this is on the track)
i went down this path as i drive a lot and like the ability to drive it like a manual or like an auto.
although i have no experience with auto skylines, a few years back when i had a auto commodore i had the box rebuilt with a street/strip shift kit + histall and it was definitely worthwhile doing!
it'll snap through the gears instead of sloppy lurching on shifts, way more satisfying to drive
if you can find a place that'll modify your torque convertor or go a proper histall it'd definitely be benefitial as far as getting it on boost from a standstill, i had a centrifugal blower on my commo which wouldn't start really moving til 3k but once i got the histall it'd just smoke the tyres off the line
All fast torque converters do a "more stall" which is basically a standard converter with the internals tweaked a tiny bit if a high stall isnt wanted. I've installed an MV shift kitted valve body into a 34 4 door and it was a pretty good piece of gear. To get it done by someone in perth give Allfast a ring as the guy that runs it also have a transmission shop down the road and he's quite good at what he does.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
    • Yep, agree with all of the above added on too. I just love the age old "what boost were you running?" Question without getting any other surrounding data. IE, may have ran 20psi, and lived for 12 years, but it was an 80 year old granma driving it to Bingo once a week and never took it over 2500rpm.
