hey guys my gf got a 34 with tiptronic auto. just wondering if anyone has had a shift kit put in thiers?? if so who did it, how much was it n did u get much improvement from it in fuel economy or performance n is it worth doing. just askin coz the stock auto feels a bit sloppy. in the mean time im gonna get the oil flushed n see if its any better.
I got what you might call maybe a "Stage 1" shift kit in my wagon (same gearbox but with a transfer case on the back).
Basically I took it to this guy in Bibra Lake who talked it up and then it turned out he hadn't seen one of these boxes before. So not knowing what galleries did what (there's more solenoids and valves than a 33 box) he did what he could, which was remove the accumulator plungers on the 1-2 and 2-3 shifts, and replaced them with welsh plugs.
It's made a huge difference, mostly on the 1-2 shift, I used to have to shift either early or bounce it off the limiter otherwise it would just slip (incidentally, even with all the slippage, he said the inside of the box was squeaky clean).
He didn't charge me much as we didn't achieve what we set out to achieve but to be honest, I'm not sure I would want any firmer shifts in my daily.. the place is called Global Automatics in Bibra Lake.
so it doesnt slip as much anymore while its in gear? n how harsh r the changes? like wheel chirping when it changes? did it improve fuel economy? also does the gear changing rpm change or is that to do with the computer?
It never slipped while in gear, there was just a massive flare from 1st to 2nd if the engine was making heaps of torque.. i.e. if it was on boost over 4000rpm it wouldn't want to go in to gear unless I backed off the gas or let it bounce the limiter once. Now it just gets the fuck in there!
Shifting is more positive and it would probably chirp 2nd if I didn't have 4WD. Put it in 2WD and it's highly amusing in the wet, as soon as it comes on boost, click 2nd and it shifts instantly then it's lunchbox super happy fun sideways time.
The 1-2 shift is harsher at slow speeds and I had to relearn how to drive.. I used to lift the gas on the 1-2 shift but if I do that now I nearly hit the car in front as it lurches hard.
It's not as full on harsh as say an MV Auto shift kit where the valvebody galleries are modified, but it's a very positive shift, no fucking around.
I would say it has improved economy somewhat but more importantly, it improved drivability tremendously!
Oh and when in tiptronic, the downshift to 2nd is INSTANT.
Edit: shifts may be nicer if you have stock ECU.. I have a Haltech that doesn't talk to the TCM so the ECU doesn't cut ignition when it comes time to shift, I also think that is why mine had so much trouble trying to shift into 2nd.
Edited by bubba
i just recently put shift kit in my 34 4 door. purchased the valve-body kit and the shift solenoid from M.V Automatics.
got it installed at Wangara Auto's.
its like driving a different car. gear changes are instant. 1st - 2nd can be a bit harsh but you learn how to drive it nicely.
the car will light up the rears going from 1st - 2nd now... :-) (of course this is on the track)
i went down this path as i drive a lot and like the ability to drive it like a manual or like an auto.
although i have no experience with auto skylines, a few years back when i had a auto commodore i had the box rebuilt with a street/strip shift kit + histall and it was definitely worthwhile doing!
it'll snap through the gears instead of sloppy lurching on shifts, way more satisfying to drive
if you can find a place that'll modify your torque convertor or go a proper histall it'd definitely be benefitial as far as getting it on boost from a standstill, i had a centrifugal blower on my commo which wouldn't start really moving til 3k but once i got the histall it'd just smoke the tyres off the line
All fast torque converters do a "more stall" which is basically a standard converter with the internals tweaked a tiny bit if a high stall isnt wanted. I've installed an MV shift kitted valve body into a 34 4 door and it was a pretty good piece of gear. To get it done by someone in perth give Allfast a ring as the guy that runs it also have a transmission shop down the road and he's quite good at what he does.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
