All vac hoses have been checked and checked again. The ignitor was not removed or disconnected for the spark plugs. The little black wire is bolted in the same place it has always been. I did just give it a quick run over with some sand paper to clean it up though
When you say your car wouldnt run well with the new HKS BOV first installed, Can you describe it?
Would it rev free or struggle to build rpm?
Did it feel like a missfire or engine cutting out completely, if so at wat rpm?
Edited by just_matt
Wouldn't idle without me playing with the throttle, And would missfire when the engine was labored. Building any boost would cause more lag.
Never went above 4k but it would do all that at any and all revs. Would only really drive smooth with no Boost what so ever.
Any luck yet Mate?
May need to check the fuel rail pressure?
Try disconnection fuel pressure reg, blocking hose so there is no vac leak into manifold, and crank it. I think this will give you full fuel pressure...
Or also try tuning the key on (wait 5sec) then off, then back on about 5-8times before you crank it (fuel pump might be getting lazy, but if its failed this wont help).
You may need to check your plugs if your have been turning it over alot with out it firing.
When you looked at the plug last did they look 'wet' from unburnt fuel?
An Injector 'Noid light' will tell you if injectors are being fired.
No luck yet, Did give it another try this morning and noticed that I couldn't hear the fuel pump doing its little start up noise before cranking. So some time today all the plugs will comes back out to see if they have had fuel hit them and I'll go from there.
try starting the car with the throttle all the way down. if it starts but then stalls after you take the throttle off, then try cleaning the AAC valve, i had trouble with it once before, it was screwed. :S
As I tried to warn you in your original thread, the AFM measures the incoming air as it comes in. By venting the air to the atmosphere, less air came into the intake manifold than was reported and why it ran rich & crap.
b i n g o ! ! !
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
