Yeah I would be interested in Sat nav only.
Then get a Spec Doc + ipod for music.
I just like the thought of having sat nav tucked away instead of on a window suction cap, but I guess the options are endless now with touch screen tablets on the market.
Stage222, any pics?
  • Replies 66
No, the DVD rom is not there, so I guess its useless getting the screen again.
Was the TV an option on the ARX or standard?
I thought it was standard but I have been told it was an option.....
Yes, TV was an option on the ARX.
pics attached :)
Has GPS, bluetooth, WIFI etc.
Loving it. Angry Birds, Internet, Divx, SatNAV, Gsensor (0-100 times etc) Anything Android can do so can this tablet.
link:
http://www.merimobil..._p/meri0306.htm
Running headphone to the Line IN on the back of the stereo. Works a treat.
pics attached :)
link:
Nice job... Well done :)
wow looks like its a yes!
http://torque-bhp.co...-obd2-adapters/
Be careful when selecting what to use to read the ODB2 and the logic of this port is not as simple as it is on most cars found in the USA or Australia.
The M35 Stagea is OBD2 but I understand it uses the Japanese domestic protocol which is different to the protocol for the USA or Australia.
I have tried a number of readers that work on the V35/G35 that do not work on the M35. :(
This includes the BLATZ reader.
The one I know works is the Greddy Informeter touch but that has no output to an external screen.
pics attached :)
link:
Very nice.
Do like!
Yup held on via top grade velcro :) doesnt move at all and i went through the blackspur last weekend and it didnt budge!
Though you can be removed if you like.
Though i am running ultra dark tint all round so at night would be very hard to see.. if i am in a dodgey neighbourhood id pull it off.. otherwise i dont really bother.
my tablet has internal GPS!! one of the few! for internet it has wifi so i can connect to my HTC desire or you can plug in a USB next G key.
Awesome bit of kit.
Sweet.
I reckon I might go down this route for my car.
I was going to get a GPS unit and then separately get a spec doc for music.
But I reckon getting it all in one like this would be a better option.
Could also just get one of those GPS units that have MP3 players and an FM transmitter for music.
Im not sure if the ARX stereos have AUX in in the back?
Also, do you have to subscribe to get GPS or you just get it free?
nope gps is free for everyone.. the only thing that costs is the app that interprets the GPS.. i run CoPilot.. costs $50 for all of the maps of australia also has turn by turn navigation etc.. though if you do some creative searching in google you can get it for substantially less! ;)
not sure about the Aux in the back i bought a JVC that has Line In RCA in the back.. it also has Headphone Line In on the front too though i wanted the wiring hidden away..
The tablet comes with a Cigarette charger.. i just took it apart and hard wired it in behind the stereo.
Edited by Sage222
Can't you just use Google maps with navigation? every android OS can run that...and its free?
Yep you could, but google maps requires an active data feed.. so you could tether the tablet to another Android handset running a wifi hotspot OR perhaps get a tablet with a sim card slot.. but if you were looking for an 'offline' solution youd need to go the CoPilot (or similar) route
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
