hi
if you have the STD ECU and the engine is knocking - that is detonating the engine check light will NOT come on
if you have an apexi powerfc and the engine is knocking - that is detonating th enge check light will flash when knock level exceeds 60
if you have any ECU and the engine has a mechnical knock such as big end bearing - no engine check light will come on as the ECU has no way to check and measure this
https://www.sau.com.au/forums/topic/334599-knock-in-engine/#findComment-5421423
