hey guys i got an ecu and tune to fix my cars power problem (which it didnt fix) my car seems to scream and go no where until my VCT kicks in (around 5.5krpm) my car is non turbo..
so i got HKS FCON Ecu and tune and it has driven fine but it still lags to get to my power for some reason :) anyway was driving today and parked the car for a good hour or two and went and got in it and the started it up and the car was shaking and really rough sounded like its gonna clonk out and so i gave it a little rev slowly through the rev ranges to about 4krpm and it sounded like a wrx engine ( i know this is a coilpack issue, however it has had new coilpacks put in it in the last few weeks ) so i got my frend to put his hand over the exhaust and everytime i gvae it some revs a splatter of black would be covered on my friends hand??
after bout 4k rpm it would rev out smooth and normally however low revs was really really rough..
so i babied it down the highway back to bris and noticed it was running fine (idled fine and sounded fine) so i pulled over and started off in 1st again and my car was back to its normal sluggish ways but it wasnt running rough at all?? could this be a cold start issue when teh tuner tuned it?? or what could it be?
im taking it back monday anyway to pick ther brains as to what it could of been... luckily i video/recorded the idle when it was bad as proof to show the shop and let them listen
https://www.sau.com.au/forums/topic/334606-running-rough-after-a-ecu-and-tune/
VCT is OFF until about 1500, then switches ON, then turns OFF again at around 4500. If it isn't doing the initial ON, then the tune will be all wrong for the cam timing available.
Edited by blind_elk
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
