hi guy as the tittle states i've lost pressure some where and the turbo no longer spool's.
"The back story" The car when bought was standard 138xxx's, just 3 days ago I decided to add a FMIC and BOV.
I dont know if these additions have actually helped to send it on it's way, but straight after the FMIC was added, driving it away i lost all pressure but then came back
2-3 minutes later and was back to normal, the next day after starting the car and driving away the turbo made a strange whistling sound while spooling under load
but when free reving in neutral nothing this sound lasted for another 2-3 minutes but the went away and all was normal.
Last night when i started the car and started my driving the whistling sound grew louder and turned into a slight siren like sound, the car still spooled but would not go into
positive on the boost gauge, it would struggle all the way to 0 and still set the BOV off but the higher i rev the louder the sound got.
This was happening right from 0RPM till 2500-3000RPM which is about when i changed gears, then my mate fxxxed it trying to force it into positive on the boost gauge
and thats when all pressure was lost, now the car just feels like it an NA, the car's standard boost gauge for some reason still says that the turbo is spooling and building
it up to the mid point which is 0 but is this only cause of the air passing through the airfilter?
Can anyone please help as i dont know JACK!! about mechanics as for the car its a
Series 2 R33 GTS-T with the new additions aside its still got the stock ECU, should i have replaced it before adding these item or atleast remapped the standard one?
Someone told me i blew a seal in the turbo "on the inside" i dont know if this is true, another told me a compression leak.
Did i just blow mine up? Could i rebuild a busted turbo or should i just buy a new one
Man i dont know but i really appreciate all of those who take the time to read and reply
Cheers
https://www.sau.com.au/forums/topic/334626-turbo-not-spooling/
Have you set up the BOV correctly? If it's whistling, then maybe you are simply pumping any boost straight out of the BOV. Put the original back on!
And have you checked ALL the intercooler plumbing joints?
    • Welcome!  Car sounds great, anypics ?
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
