Does anyone know if the interior lights have a timer of some sort, and where it is?
The reason i ask is that mine dont work from the door switches. Light turns on manually via switch, and i know the door switches are ok as the alarm works, but i cant get the light to work via the doors.
Thanks
Edited by kjb_r33
https://www.sau.com.au/forums/topic/334660-interior-lights/
  • 6 months later...
On my nm35, the interior light only operates from the door switch if the key is still in the ignition
as long as the light swtich is in the middle, it operates when unlocking the doors from the Remote control and then switches off when the ignition is turned to ON
and when exiting the car, it turns on when the key is removed from the ignition and off upon locking the car with the remote.
But if the Key is out of the ignition the door switch does not control the interior light
https://www.sau.com.au/forums/topic/334660-interior-lights/#findComment-5714851
