i know all u guys think it pretty gay but i think it sounds pretty cool lol anyways so how do i actually get this noice the whole stu tu tu tu thing haha? i did some searching on here and found something about a pipe where does this pipe go? is there any piks of someone having one done?
block factory recirc valve (bov) and run a pod filter and you should get some good noise happening. As for perfecting pitch of the dose, well you need some TOOL to fabricate you a metal induction pipe to replace most of the rubber.
buy some pigeons. or a vl.
or just take off your bov and feel the joy of lag on gear changes while you impress all the hektic kebab spec vl owners with your epic dose.
The difference is almost negligble. Just sayin.
pls o please dont get this sound, im so un impressed with wankers who dose past me in their skylines, vls, supras and show off their hektic stu du du du du fagget alarm while thinking their cool...
just sayin
but if this is how you roll, as above.
i just think it sounds cool but as i said is there any piks? or anyone know about this pipe u need?
Do you have a pod filter or an airbox in the car? will be on the right side of the engine bay. It has been said already usually that pipe is plastic replace with with a steel one very easy to work out
yeh man have a pod filter . which pipe u talkin about? my pod goes directly onto my afm
I prefer the Shetland Pony bov.
when crammed in your back seat, windows down, and jabbed with a Parker Ball point pen at the exact same time as gearchanges, it makes the best neigh/flutter/wastegate chatter noise.
I have 2 for sale if you are interested.
but you will have to get your own pen.
pics attached.
http://www.visitshetland.com/images/dp/uns...ony-enlarge.jpg
http://www.dkimages.com/discover/previews/876/65003527.JPG
Plain brown one makes the sickest sound..
especially if I draw blood upon pen jabbing.
Just purse your lips as if you're going to whistle, then make the UUUUUUUUUU sound. Repeatedly jab your tongue to your palate just behind your top teeth and PRESTO! You have your foolly Sik VL dose.
Cost farkall too. :P
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
