  • Replies 156
don't get all sooky just because you've shot yourself in the foot and been proven completely wrong - you came on hear telling me i'm talking crap, i refute it and show you to be wrong and now you're having a cry - man up dorothy. It's not google numb nut, it's the fuel i buy from my local E85 station
anyways, it's a pity such a monster of a car has some ignorant businesses jumping on for an exposure ride..
anyways, nitto/paul/trent, what fuel system are you running on this thing??? id2000's and 11ty 044's?
so did it or didn't it get on the track?
Still with the big mouth---------I was not going to get back on this Forum but seeing you think you know everything, I just wanted to thank you for the new customers and resellers you have sent my way, for that cheers mate..........And thank you all for sending me emails telling me how much a dick this guy is.....by the way come and say hello any chance you get chump.
Piss off already, you remind me of every little shit headed 14yr old boy who thinks he's king shit behind a keyboard. How about you get out there and spend some time selling your fuel? If you were so confident, you wouldn't need to come back here every day to spout so much more nonsense. Your grammar is worse than mine, it's beginning to make me sad.
Edited by Trozzle
Yes! We're well aware that the brake light is out...
We had a professional photographer booked for Powercruise, however he was unable to attend due to an emergency, we found out early the Friday morning so that sucked!! We didn't have any vid cams there...
But, there is more footage out there, we're just waiting for it to be put up.
SS8-Gohan - yes ID2000's (at the moment only 1 set, but two will be going in), Hypertune fuel rail, 2 x Magnafuel Pro Tuner pumps, custom surge tank, bigger lines etc. etc.
Of course it went on the track! You people just didn't look hard enough if you were there...
Edited by NITTO R34
How do you find the magnafuel pumps? How would you compare them to weldon pumps?
.... 12x 2000cc injectors.. Can't wait to see the results!!!
Cheers
Justin
It definitely went out on the track, I have the brown undies to prove it.
If I can find my damn USB cord to upload the vid from my BB, I will post it for all to see. Footage is mostly of the sky, then the floor between gearchanges...but at least you can hear it...
another video lost quality in the compression but oh well. skip to 50secs if you wanna see race
Good vid!! I really wanted to stretch its legs in 4th but there just wasn't enough room. It was hard enough getting space to max out 3rd, and that is when its starting to feel really strong.
i want one :action-smiley-069:
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
