Thanks Dave,
We were extremely happy to get 1000hp on E85, not sure if that had been done before, but to push it further now we are switching to c16 and more boost. The engine had perfect compression after the power cruise event, so we are happy to step up the power and see how it goes. Obviously the GT4788R is a big turbo, so there should be plenty of room to move from its current power figure. Fingers crossed it performs well at Autosalon. If it does, we will make the trek to Autosalon Sydney with a few more goodies added to it to go even further.
Actually my friend who owns the Rockstar GTR made 1000hp atw on E85 just before Jambo, and that was straight out of the pump :happy:
  • Replies 156
It is running a big set up stroker and all the other good bits you know people wont give out there specs on the engine.
Until you ring the person who built the engine. Fact is, there is no use keeping that stuff a secret. It's all been done before. Only the tune is different. People have been making over 1k for many years, it's just a matter or how many more are coming up
True that - Most people will freely give you thier parts list.
However its all the stuff in assembly and small things that make the difference. And you rarely find those on a spec sheet :P
What is the rev limit on this? Given it doesnt fall off boost between gear changes would suggest at least 10,000? :(
However its all the stuff in assembly and small things that make the difference. And you rarely find those on a spec sheet :)
What is the rev limit on this? Given it doesnt fall off boost between gear changes would suggest at least 10,000? :D
Yeah those Nitto cranks are good for 12k apparently. Well so Nitto tell me
Guys, we just took out runner-up for Highest Overall Horsepower at Gold Coast Auto Salon with NITTO putting out 1071awhp with no nitrous!!!
Currently, we're running an Autronic SM4 ECU + CDI but we're upgrading that side of things at the moment and it's 'only' revving to 9500rpm. There is much more to come out of this car and we're looking forward to the Final Battle in Sydney in a couple of months.
The Rockstar GTR put out 950awhp (not over 1000) on E85 too, we were talking to him at Jambo (nice guy!)
It made 985awhp and that was with a slipping clutch so no dout that it will make over 1000awhp with the new clutch. It runs pump E85 and no NOS and it is going to put more boost into it soon.
Well that's strange because he told us "950" but much of a muchness - but he hasn't made quad figures on E85 yet, like we have. Yes, we do know all about that car we were talking to him for quite a while at Jambo :cool:
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
