Same problem here in an R32 GTR - clunks from the rear when driving harshly, so I put it over the pit and it has a ridiculous amount of play which we isolated to the rear diff. Next, is to remove the centre and get it rebuilt at a shop.
On that does anyone know a good place to go for a diff centre rebuild in Perth?
Do report back what they did to fix it and the cost, I have a similar issue with my R32 gtst.
Mike.
  • 2 years later...
Resurrecting an old thread.
I'm experiencing some play in the driveline after my recent manual conversion, two different types:
  • There's a slight but noticeable 'clunk' on gear change (clutch-in). This happens most of the time but not always, and doesn't seem to be related to a specific gear or speed. This is the one I'd like to get fixed.
  • There's also slight 'slack' when changing over from accel to decel or vice versa. This feels quite similar to other manual cars I've driven but I'm not sure how 'tight' it's meant to be with an RB25DET gearbox?
I had a look under the car, I could rotate the front part of the tail shaft probably 2mm by hand, the rear part was harder to move. This is with the car in gear and handbrake on.
Which part of the driveline should I look at first?
What's the best way to check the condition of the tail shaft centre bearing?
From your symptom description I would suggest the centre bearing the tailshaft would be #1 suspect.
In reality, I find that it is every single point in the driveline adding up. I have play in the tailshaft, some in the diff, some in the rear CVs and some in the rear hubs. Not enough at each point to be concerned about, but added together they create a hell of an annoying clunk in my driveline.
Thanks GTSBoy, I'll start from there! I wouldn't be surprised either since the tailshaft is a combination of my R34 sedan rear half and an R33 coupe front half from the wreckers.
Just a couple of more observations from today:
This seems to come from behind the driver i.e. centre bearing, diff, or drive shafts. Centre bearing is currently the prime suspect.
This seems to be more in the front side so clutch or the gearbox itself. I reckon it's the latter.
I'm not too fussed about this one but the clunk on gear change is more annoying so need to get that sorted.
I just checked this again with handbrake on and gearbox in neutral. There's about 8mm of play in the diff, measured on the outer ring where the tail shaft joins the diff. Not sure if this is a little or a lot?
I also did the 'diff test' and opposite wheel rotates the same way when turning so it's definitely is viscous diff. Might be time to upgrade...
Edited by V28VX37
  • 8 years later...
Most of my play is in the half shafts. What do people do about this? OEM are pretty expensive. Like $1,600 each.
I can rotate a wheel about 15-20mm at the outside of the tyre, is this too much?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
