Theres a nice set of 17" 5 spokes at my local jap wrecker, attached to the remnants of a stripped-for-wrecking R33 GTS. Anyone know if they are likely to be a suitable offset for an R31 ?
I'm not sure on the width but they're running 225/45's
https://www.sau.com.au/forums/topic/33486-r33-gts-fitment-17-rims-on-an-r31/
Erm, hate to state something so fundamental, but have you ever seen an R33 GTS? by that I mean not a GTS-T ? The non-turbo GTS has the same four stud pattern as the R31, silvia, cefiro etc etc, I'm not sure on offset however.
skyline boy was :Owned:
:P
31s, I believe, run something like a +25 offset on their standard rims, and it's usual to decrease the offset as the wheel gets wider. So fitting a wider rim would require perhaps +15 offset, certainly not a +35.
It's likely the rims you're interested in are 17x7s with a 225 tyre.
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 馃檹馃従
    • Sport. I didn鈥檛 rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
