Hi all
My beloved R33 is dying
It started to lose power on boost a few days ago.
Today it got worse real quick
It started to hesitate and had no torque at all
It was harder to keep idling and started to get harder to drive
It sounded like it was sucking heaps of air and was backfiring
No power on the way home from work
no acceleration at all
!00KM/H on freeway took about a 10KM runnup it was running so bad
Hills are 10km/h
The first warning lamp came on (CAT temp)
Now I have it home it sounds like a truck when I start it up and struggle to keep idling
I have reset ECU Will now look at how to put it into diag mode
I have also jacked it up and considering taking off the CAT and having a look
Any help would be appreciated heaps
Edited by fletch63
https://www.sau.com.au/forums/topic/334885-r33-dyinghelpplease/
Ok now i've put the kids to bed I've looked at the ecu and can't see where the screw is to turn in on to diag mode
I am working in low light
Ihave checked for air leaks and all OK
Can any one tell me where the screw is for a single LED ECU
Cheers
wait a minute
after close look I can't see any LED or screw
I will plug back in and see id it works like a no LED ECU and shows up on the dashboard
Edited by fletch63
fuel pump dieing?
try another afm also
make sure u take a really good look at all the intercooler piping and vacuum hoses, a tiny crack can be hard to see if its on the underside etc
fuel pump is an in tank one and you can hear it prime up when you turn it on
I thought of disconnecting AFM but couldn't even get the plug off
HELP!!
The ECU diags was a dead end
I plugged in the ECU and turned the key and the engine check light came on as did all the others???????
HELP!!!!!
fuel pump dieing?
Thanks man appreciate your help
I am in Woodvale
I don't think I can drive my car
It is running really rough
It won't idle, It accelerates real slow so traffic builds up behind me
I can just crawl uphills
It seems like it can't get any fuel
So Im about to check the filter
Id like to then check fuel pressure but how???
I know it sounds like an air leak but I can't find any
Sounds like a truck with no exhaust and suckind lots of air sound
I am in Woodvale
Get it towed to the closest workshop, don't drive it you'll just make it worse.
Taking the wifes galant to work...NOOOOO
Anyone know a place close to Woodvale that won't rip me off
Also will attempt to take the CAT off tonight
After all the CAT temp light did come on for a while
Edited by fletch63
Hi all,
The latest news is that I got the no LED ECU to go into diag mode and it all came up good (55)
I then had good look underneath and found there was a nut missing where the turbo bolts onto the front pipe.
Because this is where the loud noise seems to be coming from and the symptoms seem to agree maybe its just that
But there are no signs of a leak and it all looks tight and flush (held in with other 3 nuts)
What do you guys think???
you even said it sounds like its sucking lots of air , probably is
YEAH MAYBE BUT I CANT FIND ONE
SOUNDS REALLY LOUD AROUND THE TURBO/EXHAUST AREA
MOTOR SOUNDS OK BUT HARD TO KEEP IDLING AND NO POWER AT ALL
THE ONLY WAY TO BE SURE I SUPPOSE IS TO TAKE EVERY HOSE OFF 1 BY 1 AND INSPECT IT
ANY IDEAS WHICH WOULD BE THE BEST WAY TO APPROACH...ANY COMMON ONES ETC
ANY ADVICE WOULD BE MUCH APPRECIATED
The leak will most likely be in the least accessible place possible, it's Murphy's Law :D
I have taken your initial advice
booked into Hyperdrive on Saturday and yes I will have it towed
Andrew was very helpful
I think its either an air leak or turbo gasket
hope no more damage
Thanks for your advice
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
