I have taken your initial advice
booked into Hyperdrive on Saturday and yes I will have it towed
Andrew was very helpful
I think its either an air leak or turbo gasket
hope no more damage
Thanks for your advice
No worries, they'll look after you, and on a hoist will identify the problem much quicker :D
Had the same problems on my Ceffy, I checked and fixed:
Ignition
Fuel Injection (including fuel cleaner)
Air Flow Meter
Throttle Position Sensor
O2 Sensor
ECU
I ended up finding coolant in the heads over 4, 5 and 6, and about half a litre inside the crank...no idea how it got there, the oil looked all good, and water levels had barely dropped....so .... yeah, hope for the best but be preparred if it doesn't go down that way.
Ahhh the reason i love BMW's so much. They just don't go wrong.
Problem after problem with the Skylines =\ (no offence intended).
You gotta take the good with the bad
With BM's you have the reliability but you have to deal with driving a boring ugly car
no offence intended
No offence taken mate :)
Also, to add to your comment specifically of driving a "boring" car - to be completely honest, I enjoy driving my BMW more so than the Skyline. Don't get me wrong, the Skyline was nice to drive with the power etc, but the beema just has the luxury, smoothness and mine being a 2.5L I6, it's not slow at all.
Honestly, I enjoy driving my beema and having some fun in it more so than in the skyline, but don't get me wrong, i still love my skylines :P
Sorry dude just was in a bad mood because my car died
Nice looking car
still hate bm's tho
Have you checked your coil packs? I recently had a similar problem, back firing no power wouldn't idle properly i assumed a pipe/hose had come off but they where all fine. Then checked my coils and turns out one of them had completely melted.
Swapped a new one over and is running fine again.
I am back on the road
Thanks for everyones help
Most thanks to the guys at Hyperdrive who did a great job at
a very reasonable price
It ended up being the cam angle sensor AND camshaft stripped
where they connect
Both had to be replaced
This caused the exhaust manifold to crack right down the centre vertically !!!!!
The turbo gasket was also gone
At the same time I had my 100K service (timing belt + pulleys and water pump)
The rocker cover gasket also needed replacing
Now it goes absolutely brilliant
Pulls harder than ever
Life's good again! :happy:
Good to hear mate.
and to make the commetn that they looked after you and pricing was reasonable for all that work must mean it was good.
Most of the time you have to die a little inside and pack away the credit card for a couple of months as you pay those kind of bills...
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
