I have taken your initial advice
booked into Hyperdrive on Saturday and yes I will have it towed
Andrew was very helpful
I think its either an air leak or turbo gasket
hope no more damage
Thanks for your advice
No worries, they'll look after you, and on a hoist will identify the problem much quicker :D
Had the same problems on my Ceffy, I checked and fixed:
Ignition
Fuel Injection (including fuel cleaner)
Air Flow Meter
Throttle Position Sensor
O2 Sensor
ECU
I ended up finding coolant in the heads over 4, 5 and 6, and about half a litre inside the crank...no idea how it got there, the oil looked all good, and water levels had barely dropped....so .... yeah, hope for the best but be preparred if it doesn't go down that way.
Ahhh the reason i love BMW's so much. They just don't go wrong.
Problem after problem with the Skylines =\ (no offence intended).
You gotta take the good with the bad
With BM's you have the reliability but you have to deal with driving a boring ugly car
no offence intended
No offence taken mate :)
Also, to add to your comment specifically of driving a "boring" car - to be completely honest, I enjoy driving my BMW more so than the Skyline. Don't get me wrong, the Skyline was nice to drive with the power etc, but the beema just has the luxury, smoothness and mine being a 2.5L I6, it's not slow at all.
Honestly, I enjoy driving my beema and having some fun in it more so than in the skyline, but don't get me wrong, i still love my skylines :P
Sorry dude just was in a bad mood because my car died
Nice looking car
still hate bm's tho
Have you checked your coil packs? I recently had a similar problem, back firing no power wouldn't idle properly i assumed a pipe/hose had come off but they where all fine. Then checked my coils and turns out one of them had completely melted.
Swapped a new one over and is running fine again.
I am back on the road
Thanks for everyones help
Most thanks to the guys at Hyperdrive who did a great job at
a very reasonable price
It ended up being the cam angle sensor AND camshaft stripped
where they connect
Both had to be replaced
This caused the exhaust manifold to crack right down the centre vertically !!!!!
The turbo gasket was also gone
At the same time I had my 100K service (timing belt + pulleys and water pump)
The rocker cover gasket also needed replacing
Now it goes absolutely brilliant
Pulls harder than ever
Life's good again! :happy:
Good to hear mate.
and to make the commetn that they looked after you and pricing was reasonable for all that work must mean it was good.
Most of the time you have to die a little inside and pack away the credit card for a couple of months as you pay those kind of bills...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
