330kw Sr20 Fs
hey guy's got my sr FS
*Arias 40 thou over size forged pistons
*Arias Chrome moly rings
*Scat H-beam rods
*ACL race bearings (main and rods)
*ACL race bearings (thrust)
*Full genuine Nissan gasket set
*HKS multy layer metal head gasket 1.6mm
*HKS heavy duty valve springs
*HKS Camshafts step 3, 264 EX and 272 IN
*HKS adjustable cam gear inlet and exhaust
*Tomei solid lifters
*Tomei rocker stoppers
*Brand new Nissan rocker arms
*ARP mains
*ARP headstuds
*Trust TD06-25G 10cm turbo with polished front comp cover, fully rebuilt and balanced by ATS
*Custom high mount steam pipe manifold
*HKS external gate 48mm with screamer pipe
*Sard 850cc injectors and plugs
*Greddy inlet plenum
*Xtreme custom made GTR clutch to suit SR20 1600kgs solid centre with Moly flywheel
*RB25DET gearbox with custom bellhousing
*Head was faced, valve stems seals, acid dipped
*Block has been bored, faced, tunnel bored, crack tested, honed, acid dipped, crankshaft crack tested, timing chain cover machined to suit both all done by Chris Milton Engine Developments.
Any questions just ask thanks dave
im after 15,000
Edited by ddm_s15
 Share
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
    • Mint. Good to see another GTSt getting love and coming back to life. Did I miss what colour you are going to wrap it?
