Hi all, there was a problem with my earlier thread. Got some error while posting new topic but I think it has been rectified now.
Anyway.. my v35 coupe Check Engine Light is on. Prior to that happening my driver's side power window wouldn't go up but I have managed to get it up now after slamming the door real hard while holding the window switch up. But before doing that I was popping out the fuses and checking them one by one for blown fuse. Although I didn't find any blown fuse but I have accidentally inserted the O2 sensor fuse in the wrong slot. I put the fuse in the next slot which is not used instead. Now I have put it back into the correct slot. I think that was the cause of the Check Engine Light. But after putting all the fuses back into order the light still won't go away. Does it supposed to go away by itself or I need to take it to the shop and get it cleared?
Also just to make sure my fuses are in the right place, would anyone be kind enough to take a photo of their fuse box and put it on here so that I could compare? The fuse box is located underneath the steering wheel next to the accelerator pedal. You won't miss it.
My fuse box is attached.
Thanks and much appreciated.
Edited by interfooler
https://www.sau.com.au/forums/topic/334905-check-engine-light-comes-on/
