  • Replies 137
Posted Images
  • 7 months later...
Oops!
Was just sent these links by a friend......
Pretty sad to see it like this after all the hard work that was put in.
Car was sold in March to make way for a 996 GT3 cup car (which turned into a pregnant wife instead)
Check out the small gif 'video' in the link below too
http://i69.photobucket.com/albums/i66/geoffwnz/Skyline.gif
Wellington, New Zealand. Seaview Sealed Sprints event.
Edited by OLLIE_NZ
I'd just spent the last 20 mins drooling over this build, to see it busted up is a real shame. At least it looked liked it had some real good use before its demise!
  • 3 weeks later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
