hey folks..was thinkin about what someone said in the forums that an RB25det conversion for a 32 Gtst is a great improvement on the car performancewise. It will be more reliabe too since its a later model engine. Also another factor is that I read these forum quite a fair bit and I have read that the RB20's lack torque, will get smoked by 33's, 180's, s14/15, wrx, with similar mods, ect.
Then again, I have also read that an R33 turbo replacement for the rb20 one would be an improvement as well and much cheaper too.
I am really close to going to either J-spec or Prestige to find me an 89 32 model under the 15 year rule due to your helpful advice to not going to a dealership to pay almost 18k for one in crappy condition. So my questions are..
1. I have called autofair here in melb and they are askin for 5k for the rb20 to rb25swap including installation. Are there any other tuning shops in melb where they also supply/trade in rb's and do the installation? and how much would this also cost inc labour.
2. should I just abandon the conversion and just do the r33 turbo swap? if so how much would this cost and would this increase noticeable torque/power?
3. as a cheaper alternative, should I just find me a 32 GTS and have the conversion done? and is the gts gearbox/clutch strong enough for the 25t?
4. Does r32 gts come in M- spec or the m-spec are only for gtst's ?
5. im 28 this year at rating 2. how is insurace going to be with full comp with the conversion? currently paying 1k a year for the corolla.
I know you folks are saying why not get a 33? I wouldnt mind one but I just love the style and poise of the 32's, and with the 25t it would be a great cruiser, with good overall accleration/torque, and a stock looking unstressed engine to boot ;).
Yeah Yeah I bet u guys are saying why dont u get the car first before you think about these things...well the skyline bug has hit me :headspin:.
thanks guys..any advice would be greatly appreciated.
https://www.sau.com.au/forums/topic/33493-to-rb25-or-not-to-rb25/
1. no idea, you'd probably only want to consider this if you have a spare rb25 sitting around. im sure you could mod the rb20 quite easily to get some more power. ive seen the smaller 2.0 litre det's blow away 33's rb25det's, particulary the sr20det. much more lighter vs 33. i've seen a silvia with an rb20det and it was quite laggy with an engine swap done on it. not sure what mods it had, could have just been a stock rb20det so probably not a good comparision. the guy who had the silvia drove my 33 and was amazed how fast it spooled up vs his rb20det silvia
2. search on the forums here, there are considerable gains from swapping the 33 turbo, not sure how much though
3. converting a gts to a gtst is probably the hard and expensive way of doing it, check out some threads in the N/A forums regarding conversion of N/A to T you need to consider engine compression, injectors, ecu, does the turbo direct bolt on, ecu upgrade, brake upgrade, intercooler addon, and other various bits need for a proper turbo conversion
4. not sure, pretty sure m-spec is gtst
5. insurance for N/A skyline vs Turbo skyline is jack all, there was a recent post in the N/A forum regarding insurance for N/A vs Turbo, the difference was around $300 for the most common models. The main insurance component is cos its an import, the turbo factor only increases it a little
if you want a turbo car but the turbo model, its much easier, cheaper and better for you. also the resale value of a stock turbo model is more than a non turbo converted to turbo
5k JUST to swap the engine? plus dont think because an RB25DET is newer it is more reliable... it depends on how that engine has been treated... i bet my RB20DET is probably healthier than a lot of RB25s and vice versa.
seeing as ur buying an 89 model why dont u just buy one thats already modified... theres a few floating around with big turbos on em and FMICs that will kill a high % of cars on the rd including r33s.
u could go one better and go for the neo6 rb25det with low ks but ur looking at about 4k+ for the engine alone unless u can get someone to ship it in for u cheap.
my advise would be to import an 89 (if u had to..) thats already got the gear.
another option is to buy one with minor mods like clutch... maybe an fmic and pod and then just hiflow the std turbo, do the injectors, afm and fuel pump and u should be more than happy
yeah it works out to be about about $21k for a pristine 93 or so GTR as opposed to ~$17k for a 1989. When I worked that out I don't see why all these people running around like their heads cut off to get a 1989, its not like you'll never be able to bring in a 32GTR after the rule change...
same with the 32 GTS-T.. don't be sucked into buying an 1989 just for the sake of it unless u can find one underpriced and with stacks of mods.
I been thinking about this also, for my "undecided" future plans which change every 5 mins like everybody else ;)
My rec. is to get an AUTO gts-t... stock as you can find it. Seeing as nobody is after them the demand will be really low.. Just using yahoo as a rough guide, I think you could get a really nice one for around 200,000 yen. The auto's often seem to (well at least look) to be in better condition. If you find a 92 or something year, get it, bring it in under SEVS - the increased costs of compliance will be offset by the newer year, hopefully better condition, and less demand (coz people are stupid and want a 1989 just "cause" geoff says). If its an 1989, maybe something silly like $7k on the road.. maybe SEVS version $10k. Anyhow, then drive it for a bit, see whether u like it or not as is.. THEN.. pick up RB25DET w/ manual box and engine for around $4500 and get it installed.. sell ur old RB20DET for $1200 (plenty of ppl want em). Either way you'll looking at around $14k for a nice R32 with full RB25DET conversion with all the benefits the RB25 has.. and rip lots of people..
I wouldn't worry about condition like people are saying - an RB25 or an RB20 can be equally hacked after that time...but they're pretty strong, how many people do you read on here have a completely blown RB20DET without being stupid? (not many!)
That conversion price looks great and is another option, almost too good! Wanna look into any hidden extras, and the 32 gearbox won't hold up as long as the 33 if they're just keeping that in
i was looking into getting an RB25DET conversion on my car...
other than the engine u also need, all wiring harnesses from both R33 and R32, plus a custom ECU, most preferably a Power FC if you are gettin an RB25 conversion, and other bits n pieces you need to get it to work together. (and no even tho an RB25DE was fitted to a R32 it had a completely different ECU, engine compression etc.) R33 ECU's are not that easily programmable as R32 ones.
All in all, if you're gettin it done all up for 5k that's a bargain, but if you wanna make sure that the car is healthy has great response then u'd be lookin at 4 to 5k just on parts alone.
yeah I have been curious at the condition of these 1989 models my self, and also wonder if anyone here has purchased one from risbey or craig. Just ike predator - I also have one of those undecided future plans which change every 5 mins :headspin: , even to the point where I was thinking of getting a sprinter and just spend some $$ on that to make it look & go like a jap spec levin.
Paul33: When I was talking about the GTS conversion, what I meant the process of taking out the GTS engine and drop the 25t/other goods in there from a front cut out of a 33.
Inark: I was seriously looking at buying your car at one point ( i think it was you selling )...the black clean looking one you had for sale but didnt have the $$ back then..( and still dont have the $$ right now but close )
funk: yeah thats what I was quoted .. around 5k on the road. This includes them keeping the rb20/ecu, however this price doesnt include the gearbox.
R34Gttr: Sure I could try that..but I doubt there would be any available fer sale..
I also gave craig an email a week ago about 89 models, and he replied that just for a hypothetical budget of 11k and recommended some really nice grade 3.5 1989 model and still have change left over from that as an example of the prices.
one of his quotes were....and Craig if you see this i hope you dont mind me quoting ya ;)
"There should never be any reliability issues with a skyline as long as you get a
good car to start with, luckily that is exactly what we are good at. If you get something that has been well looked after in Japan then continue to have it serviced properly, then there should be no problems. "
One reasone why I considered jspec, is that from what I have heard from the people in this forum he is true to his word and trustworthy as a lot of you guys claim, and he also is based here in Melb. So if he is true to the above quote then I guess he is a viable option. what ya guys think?
I really appreciate all your input on this guys
Ok. Im going back to Grand Toursimo 3 and get all my R32's some rims ;)
thanks again for the replies.
R34 GTTR do you read b4 u post? :D I just mentioned in the post above that the RB25DE (notice no T in the engine) is completely different to the R33 engines, and it has a different ECU, different compression, different harnesses, and most importantly is n/a (and its a bitch to convert to turbo).
Me n Danny (autotrust) on the forums are good amtes of the guys at J-Spec, and we're both getting parts for our cars thru em as we speak.
I guess 5k is OK if they keep your engine etc (they'll probably fit it to a 180sx).
Right now me n the guys at J-spec are tryin to figger out a cheap easy way to get an RB25DET of a highly worked RB20DET into my car atm. I'll let you know what we decide on and how much it ends up costin.
if you wanna spend 2k more you can have my GTS :D One thing about 89 models is that it lacks a few options that the post 91 models had (like an LSD, better trim, climate control, sports suspension, and they used a different EEPROM chip in the ECU ... which is a must if you wanna remap your stock ECU). They were available to 89 GTRs but not to other models.
I have done the sr to r32 conversion and have seriously considered the rb 25 into r32 conversion cost for the rb 25 in to r32 with and rb 25 gear box (much stronger) ould be around 5-6k buying a gts and converting is also a good way of going if the inital purchase price is quite a bit cheaper than the gtst.
I could have an r32 rolling shell in a month or 2 as I'm putting the sr 20 into my cefiro.
let me know if your interested. that would be a good base to use for an engine conversion plus its already here and has reg etc. plus the price wont be stupid
cherrs
meggala
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
