Hel Stainless Steel Braided Clutch Line Group Buy
  • Replies 187
After one to suit R32 GTST with R33 slave
The Hel R32/R33 GTST clutch line is identical so therefore it shouldn't matter. Does that sound correct to you? What is on there at the moment?
LIST UPDATE
1. PMR33 - R33 GTST
2. 89CAL - R33 GTST
3. 33DRIVER - R33 GTST
4. MATTIS96 - R33 GTST
5. GIMPS-R34 - R34 GTT
6. DYSONEST - S13
7. JPCR33 - R33 GTST
8. GTR32R - R32 GTR
9. NA BEAST - R33 GTST
10. ADRIAN P - R33 GTST
11. MARK660 - R33 GTST
12. GOTHIK33 - R33 GTST
13. MR SCARY - R32 GTST
14. TYPEVU - R32 GTR
15. BLAGS - R33 GTST
16. SKINS - R33 GTST
17. HIBINO - R32 GTST
Edited by PM-R33
just running RB20 box and slave atm. Putting 33 box and slave in when it arrives. I assume they're the same as people just swap the slaves over. So yeah, R32 GTST one should be right.
So that's nearly 20 people, might aswell see if it gets to 30 again and I'll end it at that.
Edited by PM-R33
so ive just found this from a guy who just did a manual conversion on his stagea: "Clutch line - 650mm Long with banjo bolt on one end and jam nut on other."
he used an R34 slave and master, rs4s runs an R34/GTR pull clutch so im going to have a stab at an R34.
EDIT: i am retarded, my housemate has an R34 GTT and it only just occurred to me that i should compare them. same same.
R34 GTT please.
D.
Hahaha too easy man, cheers.
LIST UPDATE
1. PMR33 - R33 GTST
2. 89CAL - R33 GTST
6. DYSONEST - S13
8. GTR32R - R32 GTR
18. J RED33 - R33 GTST
19. OJR32 - R32 GTR
20. PINTALINE - R34 GTT
Edited by PM-R33
I wonder if nissan fast could helP with part numbers if anyone else has stagea etc problems. Couldncompare stagea lines/parts with skyline models or something? Unless the previous post has cleared that up lol
Any more takers?
If some of you guys that allready have my bank details want to start sending through the money that's cool. I'll leave the group buy still open till the end of next week like I said but i'll start PMing every one to make payments so we can get this puppy on the road.
Edited by PM-R33
Compared all 4 parts of clutch line for WC34, all parts match R34 GTT (RB25DET MT5) See attached doc for all 4 parts of hard lines for WC34 Stagea
clutch.doc
Hope this solves.
Edited by Adrian P
sweet, Nissan Fast saves the day again lol
Ill send money your way on Wednesday when I get payed Phil... Im just back from holidays so the bank account is a bit low lol
Hey Phil,
Chuck me down for an s1 r33 gts-t please mate, as per our PM convoy.
I'm skint until next Friday. Ok to pay then?
Cheers,
Aaron
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
