Hey guys,
tried posting this Sunday but wasnt working on the forums
the cars been off the road for a few days and i need help with getting it back on
i was selling my non-turbo calipers and i needed to put the turbo ones on
so i unbolted the non-turbo ones and bleeded the lines
i then bolted the new brake lines up to it and started the car whilst pumping the brake
but the brake fluid had gone everywhere
i bolted them on tight, so does anyone have a clue to what could or may have gone wrong
cheers
https://www.sau.com.au/forums/topic/335009-need-help-with-brakes/
what do you mean by "the brake fluid went everywhere".........you didn't pop the pistons out by leaving the pads out by any chance?
nahh the brake pads were in
does the hole from the brake hose (the end nipple bit) need to be alligned with the nuts hole through it so the fluid flows through it?
the problem is photos really cant explain the problem because all i can show is a brake line going into the caliper!!
im just trying to see if people may know whats wrong with the line because i was told a staight transfer of lines should be fine and just bolt it in
i did exactly that and the fluids squirting everywhere and the problem is my car isn't movable!! do you reckon RAA would have a clue what it could be?
RAA doesnt fix up home DIY gone wrong...
Did you bleed the lines when you fitted the turbo calipers on?
Can you trace where the brake fluid is leaking out from?
yes i bleeded the line and fitted the new ones on
i then tested them out when i was completed and they leaked from the nuts where they meed at the caliper/line.. which is what i touched
all that needs to be done is bolted in
Have you put the little copper washers back in??
yeah i put the copper washer back.. thankss for the advice though
Did you put a little sealant onto the thread of the nuts before you tighten them in?
nah i didn't what sealent would you recommend? thanks for the advice
diff diameter brake line connections?
unsealed bleed nipple ?
-D
might be worth checking if the NA brake lines have different connectors to turbo brakes, i doubt it, but it is a possibility.
also s1 and s2 R33 brakes may be different
thats truee
i will have to look into it cheers for the advice
line are different
same as on s13
need to pull the olive out of the calipers if your gonna use the na lines
almost 100% on this but never worked on a na so chime in other dudes
best option would be to use turbo lines though
Edited by 1400r
do it all up tight
what suburb you in? need someone to look at it?
i did the 2 nuts up tight
i live in kensington park around a 2 minute drive from the parade
i actually noticed while doing it that the hit had a hole hollowed through it and the nipple had a parrallel hole in it which delivered the fluid..
i was thinking do you reckon they need to be alligned?
What needs to be bolted in?
Is the caliper installed over the rotor?
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
