Hi there,
I have an r33 4 door that i got about 2 months ago off a friend of mine, I have been having an ongoing issue with bad boost creeping and spiking. I have a standard turbo running front mount and split dump pipe ( apparently bought off a guy on this sight that makes them), and a pod. now as soon as i go full throttle, the boost just keeps going past the actuator setting anywhere from 10 to 14. I am not running a boost controller. I have put a piece on the hot pipe to run line to actuator, and also replaced actuator aswell. Nothing changed. still over boosting. I detached the actuator arm today and wired the flap open as far as it could go and went for a test drive. Still the car boosted up by about 3000 - 3500 and kept rising to about 9 psi, maybe even 10.
With it open, shouldnt i only get maybe a couple psi by redline, not 9 or 10. I am thinking the split dump has something to do with this, I have checked for boost leaks everywhere i can, and replaced some hoses. I am leaning towards going back to bellmouth dump, i have been told they a a lot more stable on boost and keep the split for when or if i decide to do ecu and tune.
Anyone that has been through this, knows anything about this sort of thing, please shed some light and let me know if i am maybe on the right track.
Thanks to everyone for there help.
Josh
https://www.sau.com.au/forums/topic/335014-wastegate-flapper-issues-maybe/
Hi there,
Josh
I have the same issue with my turbo, the internal flapper hole is to small.
I opened it up by a few mm but the problem is still there,
I'll be fitting a external gate.
Nigel
I had no problem with my off the shelf split dump but if yours is catching the wastegate surely a few minutes work with an angle grinder should "adjust" it to fit rather than buying a whole new front pipe.
had same problem with a split dump, put back the origional, had same problem, put on a aftermarket bellmounth, same same, opened up the hole big as possible, fixed, blew it up a day later :)
Thanks for the replies so far, seems people have mixed views on this subject. I have also been told that split dumps flow so much freely and that can cause wastegate creep also, something to do with pressure. Not sure myself. Any ideas if I will lose much power by going back to a bellmouth.
i dont know if this could cause it, but jjr split dump pipes are pretty poor quality (if its a jjr one, but this being said, maybe a lot of them are like this), im not saying this because i hate jjr or anything but from hands on experience, when i bought one before my bellmouth, i inspected it and noticed that the hole for the wastegate pipe that joins to the main pipe is poorly cut, and in actual fact is only about 50%-75% size of the actual wastegate pipe, so say that the wastegate pipe part of the split dump pipe is the site of a 50c coin, the opening on the main pipe is only the size of a 10c coin... i fixed this by spending about an hour filing away at the hole, but all this being said i dont think i had any issues with boost creep that wasn't boost controller related, i used to get boost creep right up to 14psi (when the boost controller was set to 12psi) i fixed this by getting a evc, but a turbotech boost controller is just as good.
hope some of the this info sheds some light
split dump for sure if your problem. put a bellmouth on.
why f**k around trying to get a split dump working (grinding bits and pieces) when the split dump gives you no performance advantage? 2 small pipes has much less surface area than a bellmouth that covers the whole turbo exhaust flange, and tapers down to 3" nicely. plus, with the dump you are using the full exhaust when you are off boost = better efficiency. with the split you are only using the main pipe.
put a bellmouth dump on. I've heard so many stories of JJR split dumps fouling the wastegate, boost creep etc. However their stainless bellmouth dump is actually quite nice quality. flanges are good, TIG welding is very neat and the finish on the pipe is fine. I was really pleasantly surprised when i received mine. there is no "maybe it will work maybe it won't" as with a split dump and whether the actuator fouls. then you get your split dump working, get a high flow they fit a bigger flapper on the gate and then it fouls again!!! screw that for a laugh.
Well I went with the choice of going back to a bellmouth. Not the best solution but for now it will do. If it solves my problem which I'm pretty confident it will. There is nothing else left for me to check, I will keep the split dump for when I change turbo's and do ecu upgrade.
You running a cat converter or got a decat pipe in there?
You can check to see if the gate is catching on the dump...unhook the actuator and check its range of motion...they will never open 90 degrees, if it opens to half of that its working fine and has sufficient clearance.
Edited by NSNPWR
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
