turbots Posted August 31, 2010 Share Posted August 31, 2010 HI ALL new to this site iv got a r33 gts-t wen you are starting to put your foot on accelerator just as it starts to spool up sum times the power cuts out stil runs etc but just seems like ya took ya foot off the pedal but you didnt doesnt do it for long then it just kicks in an goes!! kinda seems like corners are stuffing around with the problem like wen ya cum out of a corner an you start putting ya foot down thats wen it does it mostly and its auto an if you put ya foot down quickly then take it off just as the boost starts cuming on it goes to stall bad an runs really ruff, like the idol is hunting been thinking that iv prob got more then one problem haha an maybe tps an oxy sensor are sad any help would be gr8 thanks Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/ Share on other sites More sharing options...
The Dan Posted August 31, 2010 Share Posted August 31, 2010 My first guess would be fuel pump or filter Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5424221 Share on other sites More sharing options...
turbots Posted August 31, 2010 Author Share Posted August 31, 2010 My first guess would be fuel pump or filter really?? it still goes well wen ya put ya foot down!! could it be the pump?? the stalling wouldnt be thoe ay thanks mate Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5424249 Share on other sites More sharing options...
The Dan Posted August 31, 2010 Share Posted August 31, 2010 Keep in mind that it IS only a guess. You need to properly test them to find out whether they are faulty Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5424268 Share on other sites More sharing options...
turbots Posted August 31, 2010 Author Share Posted August 31, 2010 Keep in mind that it IS only a guess. You need to properly test them to find out whether they are faulty thanks mate... i really thought it had sumthen to do with the pump at the start!! coz it did seem like is was worse wen low on fuel!!!! but thought if it was it wouldnt be to good at full noise!! cheers Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5424502 Share on other sites More sharing options...
The Dan Posted August 31, 2010 Share Posted August 31, 2010 No, fuel demand is greatest at peak torque which, in your case, is around 3,000 rpm most likely. Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5424510 Share on other sites More sharing options...
turbots Posted August 31, 2010 Author Share Posted August 31, 2010 No, fuel demand is greatest at peak torque which, in your case, is around 3,000 rpm most likely. dam that was fast.. you musta been waiting haha thanks.. peak torque at 3grand?? is you for real mate?? i'd say its got nothen under 4500rpm an doesnt start pulling to 5500rpm an at 7500rpm its nice he he it seems to be electrical, well i thought any way.. its only wen you start to accelerator from backing off or braking plz help.. sum body must of heard of this b4 im thinking dodgy wire or plug mayb lol Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5424520 Share on other sites More sharing options...
The Dan Posted August 31, 2010 Share Posted August 31, 2010 dam that was fast.. you musta been waiting hahathanks.. peak torque at 3grand?? is you for real mate?? i'd say its got nothen under 4500rpm an doesnt start pulling to 5500rpm an at 7500rpm its nice he he it seems to be electrical, well i thought any way.. its only wen you start to accelerator from backing off or braking plz help.. sum body must of heard of this b4 im thinking dodgy wire or plug mayb lol Hey I always check my emails in the morning and at lunch You need to test the different systems. You can't just expect that someone will have your answer. There is about 10 different things that will cause that issue. Do a search on checking fuel flow and try that first. If it's not something basic like that, then start checking the other electrical things. Don't over complicate the problem. Keep it simple Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5424545 Share on other sites More sharing options...
turbots Posted September 1, 2010 Author Share Posted September 1, 2010 Hey I always check my emails in the morning and at lunchYou need to test the different systems. You can't just expect that someone will have your answer. There is about 10 different things that will cause that issue. Do a search on checking fuel flow and try that first. If it's not something basic like that, then start checking the other electrical things. Don't over complicate the problem. Keep it simple yer thanks mate.. very true.. i allways over complicate things in steed of keeping it simple.. im starting to think its got sumthing to do with wireing to maybe fuel pump did it bad last night going over heaps of bumps round a bend an i was kinda rolling... hmmm an i gave it a fair hard time other wise an it loved it!! but still going to stall at idol would a after market blow off valve maybe do that?? umm how can ya turn the boost up with a stock ecu?? ive got a remaped ecu with no boost cut but i dont like useing it coz i think its not a auto ecu and doesnt change gears very good wouldnt mind winding up the boost with stock ecu do you need a fuel defender or sumthen ???? cheers Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5426385 Share on other sites More sharing options...
turbots Posted September 8, 2010 Author Share Posted September 8, 2010 any body else got any idea Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5435876 Share on other sites More sharing options...
toddlls Posted September 8, 2010 Share Posted September 8, 2010 Split Vacuum lines somewhere, Blown head gasket, rag stuck in pipework somewhere-start where Elite said to start checking-he knows his RB's better than just about all everywhere Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5435887 Share on other sites More sharing options...
turbots Posted September 8, 2010 Author Share Posted September 8, 2010 Split Vacuum lines somewhere, Blown head gasket, rag stuck in pipework somewhere-start where Elite said to start checking-he knows his RB's better than just about all everywhere thanks man.. its got new vac hoses.. and it hasnt got a blown head gasket!! engine is mint!! only put it in there couple months ago.. lol no rags stuck any where.. i dont think it would go/run very well with a rag stuck sum where!! it only does it when goin round a bend thats bumpy !! Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5437025 Share on other sites More sharing options...
defari Posted September 11, 2010 Share Posted September 11, 2010 (edited) edit: just read your whole thread.. Edited September 11, 2010 by defari Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5441214 Share on other sites More sharing options...
turbots Posted September 17, 2010 Author Share Posted September 17, 2010 edit: just read your whole thread.. ????? ^^^^ ?????? Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5451427 Share on other sites More sharing options...
R3N3 Posted September 17, 2010 Share Posted September 17, 2010 bov would make it try and stall when you take your foot off, put the stock one on and see how you go?? Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5452240 Share on other sites More sharing options...
dannk Posted October 21, 2010 Share Posted October 21, 2010 i would start with the spark plugs and coil packs, (1) look for water / moisture in the coil packs (2) check coil pack condition and the connectors too. if thats clear would go ahead put the stock bov back on and check all vaccum hoses by fidling and tightening if problem persists would start checking the fuel pump,filter,and idle control valve, and also throttle postion sensor. hopefully helps Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-5509071 Share on other sites More sharing options...
turbots Posted October 24, 2011 Author Share Posted October 24, 2011 i would start with the spark plugs and coil packs, (1) look for water / moisture in the coil packs (2) check coil pack condition and the connectors too. if thats clear would go ahead put the stock bov back on and check all vaccum hoses by fidling and tightening if problem persists would start checking the fuel pump,filter,and idle control valve, and also throttle postion sensor. hopefully helps HI, all of the above is good, like i have said.. checkd the fuel pump an thats fine as well.. I think all it is an has been this hole time, the wires going to the afm it sumtimes stalls wen you move them.. does any body have i wire diagram so i can see where in the ecu the afm wires go ?? any help would be gr8 Link to comment https://www.sau.com.au/forums/topic/335045-r33-rb25-running-ruff-surging-an-wants-to-stall/#findComment-6076630 Share on other sites More sharing options...
