BNR34 NUR SPEC N1 TURBO'S comes with oil lines and NISMO stainless steel extensions. Price the Nismo extensions...they are over a Grand by themselves.
The turbos are basically new...the guy that owned the NUR SPEC upgraded them straight away.
You will not buy better....basically complete and new in everyway and they are perfect for the street (can hold 1.7 bar) better than buying real secondhand.
You can alway buy real secondhand 2530's and hope for the best and they won't come with the extensions, oil line or anything else.
enough said condition is everything when buying turbos and I known you will never get another set, of this Quality for this price.
$4000 or best offer....
Phillip
0409 573 124
[email protected]
[email protected]
https://www.sau.com.au/forums/topic/33505-bnr34-nur-spec-n1-turbos/
The different between NEW and BASICALLY NEW is price.
It's as the words imply.
New is delivery k's on the car.
Basically new is not long after that they were removed and upgraded.
Your in Perth....if you were serious....I would send you the turbo's to view and inspect.
But, it sounds like your not happy, with being asked you to increase your offer.
The offer is still there....if you are serious....increase your offer....and I will send the turbo's and extensions to view and inspect.
What more do you want....another 20,000k's on them to bring them down to your offer.
You have my number (0409 573 124)
regards Phillip
CONDITION IS EVERYTHING, when buying Turbo's
So is being polite to potential buyers.
Daniel Konig
If you are not interested in buying these turbo's then please keep your comments to yourself. I'm thinking you should have a read of our rules.
Thanks
Neil.
Yes....people should alway be polite!
But not for the sake of a sale.......and not forsaking honesty.
I've had a lot of inquires from people in PERTH....waiting for the serious buyer though.
Just for the fun of it....if the buyer is eventually from Perth...he or she can have them for $3500 with the extensions and I will through in a NISMO dump pipe to go with them for $250. However, the offer ends at the end of the week.
Phillip
0409 573 124
MESHMESH
Are you interested in buying the NISMO extensions (small pipes from the turbo's exhaust housing) or the dump pipe? (the longer 2 pipes into one)
"Have you got a pick of the dump pipe?" there is only one Nismo dump pipe. It's a long 'Y' piece pipe from the 2 turbo's extensions, to the cat.
"Would you sell this seperatly?" YES, if the offer is reasonable.
"Is it a split dump?" I assume you mean do the extensions have a separate wastegate outlet. YES, they do...the turbine exhaust housing, also has a divider between outlet and wastegate.
"Do you know whether this fits the stadard turb's on the gtr?" I assume they would.
I hope this answers all your Questions.
Thanks for the inquiry.
I just would like to clear up a confusion and be as polite as possible during the process.
That is the front pipes dude.
What you are referring to as extensions, are the dump pipes. These are, what meshmesh is interested in, i believe.
I apologise in advance for my interruption.
:D
I think you understood, the exhaust pieces I described.
Yes, they are front pipe and dumps in some circles and extensions and dump pipe in another.......the second makes more sense to me.
The same applies to the term SURGE Tank and Plenum. It all depends on which terms you are use too, in conversation and what makes more sense to you. Plenum for me in this case.
No need to appoligise for interuption.......all knowledge is good.
Phillip
  • 4 weeks later...
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
