hey everyone just about finished my build and am stuck on some wiring, was just wondering if some out there can help it would be much appreciated
so i've got the 26/30 sitting in the car everything else is done just stuck on the aac valve wiring, now i got the r32 gtr engine loom and put it in and there is a 8 pin plug just before u get to the injector plugs that i have traced the aac valve wining to from the ecu, now from there i am guessing that there is supposed to be something that plugs into it and goes down to the aac valve and all the knock sensors and shit, i dont have that part.
how am i ment to wire up the aac valve???
can someone please post up some info they have and pics would be much appreciated.
thanks blocka
here's me engine bay
https://www.sau.com.au/forums/topic/335056-r32-gtr-loom-into-r32-gtst/
you are missing a section of the loom, unfortunately. you can either bodgey something up (hard without the plugs) or try and find one
For the record my r32 gtr idles happily at 1000rpm without even the vacum box etc. just the plenum (all holes blocked obviously) with standard ecu
thanks for the input JEFFWORLD2 but i would like to have it wired up,
yeah STATUS it would be the knock sensor loom \
if anyone has any pics of both sides of that 8 pin plug or any wiring diagrams that would be ace
cos i know that the aac valve has a signal from the ecu but dont know weather the other side is a 5v or an earth
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
