Haha hey man!
Dunno why I'm posting this as I'm talking to you on FB right now too! lol
Welcome!
Maybe make yourself a signature like mine below VVV
<<< And an avatar too!
Go into my controls and down the side click "edit my signature" and "edit avatar settings". Upload a pic if you can be fcked!
Looking for inspiration hey? Dude, with the amount of money you're earning, you could crank out ~400hp with ease!
Big GT30 turbo, injectors, 300zx air flow sensor, a tune up etc... dead fkn easy!
Happy browsing!
https://www.sau.com.au/forums/topic/335069-gday/#findComment-5424393
hmm, with skylines, less is more you'll find.
What more can you do? All the aftermarket body kits look horrid and like they've come from the two dollar shop.
You've got the rims, got rid of that hideous spoiler and its lowered...
maybe a "400r" front bumper?
this is a 400r bumper:
this is your standard series 2 one for comparison:
BTW, a 400R was a special edition R33 made by Nismo, its has the cool body kit and some other goodies, along with 400hp (obviously).
or a carbon fibre/black or vented bonnet?
Edited by turbo x-trail
https://www.sau.com.au/forums/topic/335069-gday/#findComment-5424408
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
