ok starting to build up a rb26 on a N1 block , i wanted to use HkS 2.8L stroker But, they have discontinued the step 3 gear :) , i fairly sure the only differences between step 2 and step 3 was the gudgeon pin size and the rods? can any one confirm?
so i was looking at Nitto and wondering how thier gear holds up? bit disappointing they don't make a 2.8L tho if their gear is strong i guess it doesn't matter so much.
so what i am asking is basically how does Nitto compare with Tomel , HKS and the like of jap brands?
https://www.sau.com.au/forums/topic/335075-nitto/
  • Replies 42
+1 for nitto parts, i use their I beam rods and oil pump in my gtr.
They seem to be made very well. the i beam rods are nice and thick.
If the 2.7 kit was available when i built my engine i would of gone with that. From memory its about $8000
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5424601
To me, the Nitto products tick all the boxes, hence why we support the brand:-
Good value for money and realistically priced
Full billet, full counter weight crank for best rpm capability and harmonics
Quality forged piston with low silicon content to handle hp
I-Beam rods with quality bolts
Can handle plenty of boost, rpm and power
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5424668
i have nitto forged pistons and rods going into my 2630 :D i compared them to the cp shit (and i mean shit) and they r way f**king better and hold heaps more power. the rods even have this little channel drilled thru them to get oil thru coz the rb30s dont come with them from the factory.
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5424754
i am sure they make some good stuff
but until my machinist says " this is the shit to buy!"
then ill wait till he says that
when he says it then ill buy it
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5424811
ok starting to build up a rb26 on a N1 block , i wanted to use HkS 2.8L stroker But, they have discontinued the step 3 gear :D , i fairly sure the only differences between step 2 and step 3 was the gudgeon pin size and the rods? can any one confirm?
the step 3 differences were:
gudgeon pin size larger on S3 pistons (obviously comes with rods and pins to suit).
also, the S3 pistons have 3 coatings on them. off the top of my head they had moly coated skirts, titanium coated ring lands and ceramic coated tops/crowns.
crank is the same from memory and rods are the same too apart from pin size.
the S3 kit was fantastic no doubt but the S2 kit is still a serious piece of gear. I wouldn't hesitate in using one for a big build.
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5424831
CP pistons are shit? Every day you seem to amaze me...
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5424901
CP's are shit hey?
Well, glad you have the facts on that one. Go look at how many GTR's use CP pistons without issue. Also, have a look at which drag cars use CP, you'd better email those teams and give them the heads up aswel.
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5424906
CP's are shit hey?
Last time i checked Godzilla Motorsport use CP and they are where in the world in drag times and make how much power. I use CP in my engine which makes 700hp at the wheels and does it with easy and i have a mates GTR engine that uses them and that makes 1000hp at the wheels and it does it easy. I dont dout that the Nitto parts are good but CP anit shit.
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5424938
yeah I wouldn't say CPs are shit. they are built to a price and for the money they cost they do a fine job. they are nothing super special but they certainly aren't rubbish either. plenty of cars use them without problem.
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5424980
This is how perfctly good parts get into trouble. The Nitto gear seems good quality, has a few cars out there doing good things and are a credible product in their own right.
They could very well be better then CP or Arias. But that doesnt make the other brands sh1t. They other brands are proven in so many builds to the point that the same bad tune, wayward sprk plug tip, failed fuel pump etc would kill a motor with Nitto pistons as quickly as CP
I question having a rod and piston strong enough to do 200hp a cylinder in a 100hp a cylinder application. Its good, but surely it maybe just adds weight, cost or something to have so much head room.
Its been proven before that std rods are good for many GTR builds, basic forged pistons are good for serious engine builds and the basic R33-34 crank is a good thing. Is 8k for 100-150cc worth it over a build using $1200 pistons, balances std rods and std crank (hell a new one from Nissan is $1000)
So, if cash is no limit...go for it....but if you end up with 330awak turbos then what benefit is all the slightly better gear.
On a +400rwkws build I suppose is when you have to start looking at the positive trade offs of some of the Nitto or other slightly better quality gear
LOL, this if course the opinion of a guy that has never built an engine and drives a std RB20 "crate motor" :D
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5425227
absolutely right. I'd treat nitto as a well priced high end option (ie for 5% of people) rather than a mass option.
when looking into the race regs for production cars, nitto were the only forged rods and pistons that came close to stock weight....all other brands were 15-25% lighter than standard. Great for me because I have to run stock weight, but its just overhead and overkill for 95% of people.
How many 1000hp engines are there in Australia?
https://www.sau.com.au/forums/topic/335075-nitto/#findComment-5425924
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
