Ha Ha ...please point out exactly why CP are shit & nitto are so fcking wonderful.
btw.. just a bit of trivia, barry calvert founder of CP pistons worked for JE for many moons before leaving and starting his own company with his brother.
And guess who makes nitto pistons..yep JE. (yes they are a lower silicon content 2618 alloy like mahle's compared to a 4032 used by cp & others)
I sure would like to hear what you think of carrillo or pankl rods too compared to the nitto items ??
Im not saying nitto is bad at all, in fact i plan on using it soon..but its not the worlds best shit either compared to other great products you say are so shithouse.
This nitto hype is too funny. :D
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5426057
  • Replies 42
i have nitto forged pistons and rods going into my 2630 :Di compared them to the cp shit (and i mean shit) and they r way f**king better and hold heaps more power. the rods even have this little channel drilled thru them to get oil thru coz the rb30s dont come with them from the factory.
My god you talk a lot of garbage, can't wait to hear your justification for such comments.
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5426110
^^ what stroke will these be available in ?...4340 ?
Can a crank be had without the rods ?...I have some Ti pankl rods coming soon.
77.7mm 4340 full counter, knife edge but no rods about $3150
may do a group buy if there is interest.
only have one spare kit in-coming and im not keen to split, wait is not long though.
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5426133
Surely the lighter the better? Why do you have to run stock weight?
Because it's in the regulations I assume, if he could run lighter rotating components this would obviously have a beneficial outcome in the way the engine produces torque and power.
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5426345
yes exactly...I have to keep within 2% of stock weight because of rules.
But the point is, yes the Nitto stuff is well engineered/ better than many parts.....but are the other ones good enough for most uses already?
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5426352
no, they measure bore, stroke, head height, deck height, combustion chamber cc, cam duration and weight of roundy roundy bits before assembly, then watch assembly, then seal sump to block with 2 seals, and cam covers to head with 2 seals each.
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5426826
how much is a bit of lock wire and a seal tool :)
jks
we used to race with a guy in 125cc and he used to kane us week after week (for 2 years) and about a year after we gave up he confessed to running a 165cc big bore kit.....
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5426853
  • 3 weeks later...
Any update on this?
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5458402
Wow,
Lol the lack of thinking of some people these days..it scares me! And to think he is behind the wheel of a car aswell!
CP Pistons are shit? Crap i better go let a rb30/26 owner know that his 1154rwhp engine has crap pistons in it :P
Same goes for a bunch of well known GTR's and i should also call Titan and let them know that all there 2000hp supra race engines are shit aswell :D
Lol next thing you know, someone will tell me that HKS and Jun are made in Taiwan,
If you have a 1500hp engine goal, you don't use a set of forged pistons designed for a 800hp engine.
You get a set of pistons made to suit that application so you get the absolute best out of your engine combination and the pistons.
You open yourself up to various materials, Billet pistons, lightened pistons, thicker pin bosses, x-forgings, lateral gas ports, anti detonation grooves, anodizing ring grooves, skirts coatings, custom ring sets theres so much that can be done to a set of pistons.
P.S: Nitto is a great brand and has some quality products! Trent wouldn't sell and promote a product if it couldn't live up to his expectations.
Cheers Pete
Edited by BOOSTA
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5464556
yogibear - call crd & ask for jim (owner) he has a great story to tell about his nitto oil pump & hence why i also use nitto...all i will say is that their oil pump can chew cast iron block bits & that wont even stop the damn thing :P
how is 'boo-boo' these days? man i miss those old classic cartoons
https://www.sau.com.au/forums/topic/335075-nitto/page/2/#findComment-5464806
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
