So Who Has A Rebuilt Motor That Didn't Last?
167 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
my starts up tomorrow.. :(
also, the fuel would also help with how long it lasts yeh?
like e85 would be better insurance than 98..
like if the tuner isnt as good than e85 will help allow for their lack of tuning skill.
would be interesting to see what fuels ppl are using on there stuffed engines?
im going e85 to keep it safe :(
The motor that was in the car when i bought it had done 3000kms on it and failed within a month doing no hard driving at all.
My current motor has done 20000km's, ~15 track days, 2 drag days and over 100 dyno pulls (Built by Dan @ ERD in July of '08). Running on BP Ultimate / Shell Vpower all its life. No fancy fuels here.
Shit happens thats out of anybody's control (faulty parts), but in the end if your builder/mechanic knows there stuff, and you don't cut corners, you can get a lot of life out of them.
  • 3 months later...
First engine lasted 12,000km on a standard rebuild, running approx 300RWKW, dropped a ring in sixth
Got a Built engine now so fingers crossed holding 400 +RWKW when shes up and goin
Mine lasted 200ks at the most... Had a built 26/30. Did a few power runs on the dyno up to 24psi and 8000rpm. Made 475rwkw.
I didnt have a oil temp guage so tuner asked me to feel how hot the oil cooler was and it was cold...
Oil cooler lines were hooked up wrong by the previous mechanic so oil wasnt passing thru the system. results are a bent crank.
also consider most motors are putting out twice or even 3 times their stock output and being driven very hard at the track etc... also it seems anybody can open a workshop and claim to be a import specialist etc...
This ^^^ Even though RB was built for power and longevity, you can't expect 200kkm+ from a engine you've doubled the power from, simply won't happen. Driving at track and such isn't such a problem, it is driving in the engines danger zone that is the problem. ie, doing 100kkm at 2500rpm average vs 100kkm at 5000rpm average isn't so much of a problem as too much boost/pressure, lack of cooling, etc.
Anyway, it is always better to buy something properly built for your power rather than building up to it (ie N1 from the get-go), so in that regard rebuilding a RB with stock stuff if you plan to do more than 20% more power is just stupid; stick forgies in, have it balanced properly, port n polished etc, and you WILL get an engine that can last 200kkm from double the power.
After watching an engine rebuild "howto" video it was interesting to see that it's not nearly as simple as getting the right parts and putting it all together and making sure it seems to be turning smoothly. once all the prep work has finished just about every stage of assembly is done twice. first time is often done with plastigauge to check clearances and then once you're happy it goes together for real. however, often in checking a later stage you have to disassemble back to an earlier stage to check the part.. so really it's like 5 engine assemblies (or more) to get a complete engine back together.
like others have said it's a miracle that so many go together and DO work perfectly. miss just one tensioning step and that bolt is going to let go and ruin your day. engine builder's warranty on a new build is extremely important.
if the shop cant do the whole job from start to finish its hard for them to give warranty
how do they know the person tuning the car knows what they are doing?
how do they know the person who owns the car isnt going to play with it and blow it up?
i know of someone who had a big $$$$ EJ25 built and was making near on 400kw all day every day
till the owner decided it was smart to replace all the hoses with silicone ones
his fancy new silicone hose to the FPR came off one day and well the rest is history
That's exactly right. That is why when I give warranty it is under the condition that I run it in and it get's tuned where I say.
When you take out all variables except the owner, it makes it fairly easy. But regardless of how an engine fails, the cause can usually be determined before the new engine is ready to go back together. That way, if the owner has stuffed something up, it can be diagnosed correctly so it doesn't happen again.
i have a RB26 built and so far it has about 26,000kms on it running fine no noise and makes good power still running stock computer and turbos so far but very happy i use it for daily driving most of the time and i hope it lasts as long as my other RB25 did :)
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
