  • Replies 313
Posted Images
Thanks Sidd
i had a go at this last night and my results were.... well, absolutely terrible!
Haha yeah I did two on the 1st - and both came out ok'ish (will post the another one up as well).
Then went camping up the beach and did 3 up there and none of them would even stitch correctly
Yeah added a quick description here under the photo:
http://www.flickr.com/photos/zennondamant/4960040974/
but pretty much you need a 360x180 pano
where you try and keep the camera in the same spot
(this might be a lot depending on how wide your widest lens is)
then you stitch them into a pano - can use hugin for this but i used my normal pano software
then you stitch it into a little planet using hugin
(its harder than what it sounds lol)
love that last one, so cool!... gotta give that a try I don't have a tripod or a wide lense
I made this pano by lining the camera up on the horizon and just shooting about 10 shots handheld... then an hour in photoshop and I have something that could have been done in 5 minutes with the proper gear lol
It's finished :cool:
my light box.... light wand, light wang, whatever you want to call it... maybe a led brush?
anyway, finished :P I'll try it out tonight if it's not to wet and see how it goes.
damn phone never uploads a full pic to picasa.
Nice Matt! Might need longer exposures as it doesn't look like its that bright. I'm going to try with a LED Torch that you use when you work on your car at night. Otherwise going to try the hard way with a 64" Octabox and a strobe inside with the power pack on my shoulder. Shall be a tremendous effort lol.
It's variable power. But when its bright its no dimmer than f**k off bright. the camera auto exposed and the light is fairly directional. It's perfect for I need. Brighter than torch and no hot spots. Might try some later before beer o clock.
Ok Managed to test the light rig out (And get a no standing ticket :'( )
Here's a couple test shots. first is the gratutitous evo shot. THis is straight outtta cam. No editting.
Now here's a black car, everyone's worst enemy.
Minor edits here. removed some bird crap, adjusted curves of pic.
^ nice looking forward to seeing more pics from the setup :ermm: So far it looks good. Maybe needs more power?
We had this swinging in the back of our car lol..
Drive back to Christchurch: incredible views
THanks for that :ermm: Will give it a try one day. ta
Dude i love your shot. Such simple, elegant shot. Would love to just sit there and relax. Where was it taken?
Man im just learning, and trying things out etc... but yea organise a model shoot and we can go have some fun.
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
