Dont get me wrong i do like that edit, but the style of processing has been done on most of the photos.. The client seems to like it which is good.
Sorry for the confusion... Cheers for the kind words.
So what exactly do you do tho? got a website?
  • Replies 313
Posted Images
Took over 400 photos on Monday, but only made time to process a few - damned Facebook and SAU are so distracting! This one is my cousin from Canberra, he was up here for a wedding and I took him to a skate park in Merrylands (same place we had our SAU Show n Shine a few years back) on Woodville Rd. This is the first time I've tried action shots like this, and I'm pretty happy with the results. :) Used a mix of Av and Tv modes, and with this shot there was too much in the way of a distracting background, so I did some RAW processing (exposure, saturation, and then fill light because he was wearing all black), then de-sat in PS, and colour splash.
Oh, and today (Tuesday) I bought a 60D!!! Haven't started using it yet, but hopefully will get a chance this week. Also, hopefully CS3 will be able to deal with the RAW files...
Woohoo! Nice job Nick!
Let us all know how the 60D is! Especially the AF i'm curious about.
Also, unfortunately, CS3 won't be able to handle the RAW files... CS5 will though, looks like you'll need CS5 OR possibly CS4. Wait and see.. I'm using camera RAW 6.2 at the moment with CS5. I'm pretty sure camera raw 6.3 will come out supporting the 60D but only with CS5.
No website (currently under construction... I'm my own worst client)
I'm a graphic designer out of a little studio here in Melbourne called Simm Design
Here are a few pages from my folio that include photography... the first few (ANZ, Monash, EastLink) are using mostly stock library imagery, whilst the hotel stuff and Canninvale towels were shot by Earl Carter, who is a top notch shooter down here in Melbs
Also includes a website I did for Stuart Crossett who does some pretty cool advertising photography, check him out at stuartcrossett.com.au
I have also put in a couple of corporate IDs I've done for smaller businesses, no imagery there
Finally there is a page with some of my photography... I'm no pro its just a hobby!
Okay I think I've spammed your thread enough now! back to posting cool photos
Thanks Kory! It's funny, even in the RAW file the photo looks so surreal (at least to me), as if I'd stitched my cousin into the background in PS.
Hmm, I might try a few test shots and see what happens anyway- if it works, then bonus! If not, then CS5 it is.
Camera RAW 5.x = CS4
6.x = CS5 :D
6.2 supports the 60D:
http://www.adobe.com/products/photoshop/cameraraw.html
CS5 for you, Nick! I'm sure some people around could help you... find a good price on it :)
everyone is posting up people pics. I haven't done to many but heres one of me and my nephew. you can pick which one i am :(
first one i used lighting, one spot. second one no lighting. just some over photoshopping ;)
ok seriously decided to buy a new lens for my canon 450D next pay
which one should i get kgo
lol but seriously, i do want to buy one and i dont want the cheapest but i only take photos for my personal pleasure so i also dont want the most expensive.
btw you guys seen these sites?
ken rockwell - http://www.kenrockwell.com/canon/lenses/index.htm
DDP - http://www.d-d-photographics.com.au/
ps am i allowed to buy a wide lens and a normal lens? i like the wide lenses but theyre not practical for much
these are the last photos i took
http://www.westcoastcruisers.com.au/Forums...st-anniversary/
Edited by Passive
No, I forbid you to buy a wide angle lens. You are not allowed to do so.
Why don't you work out what you're comfortable spending, and work out where and how you want to use your lens, then make a decission.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
