Hi guys,
Just a quick question I'm sure:
Basically I've owned my R33 GTR for about 2 months now, I put some apexi pods filters on it and just has a cat back exhaust at the moment otherwise completely stock.
Now my boost gauge use to say -11 ish on idle and boost up to abou 10 PSI, (on both my mechanical boost gauge and stock gauge), and now after a oil change (duno if it could be related at all) sits at about -2 ish on the gauges and only found that its boosting up to about 6-7 PSI? and car just seems a little slower in general..
Now I'm no engine guru but my first thought was maybe there is a leak somewhere in my FMIC piping? but figure I'd just ask here to see if this has happened to anyone else.. sorry if its been answered before but couldn't find anything.
Thanks in advanced,
Leigh
https://www.sau.com.au/forums/topic/335130-rb26-noob-question-regarding-boost/
yep, most likely a pipe blown off, or vacuum hose off. best bit if you are not sure what to look for is take it to a mechanic and get them to find the missing/split/blown pipe. easy fix.
Ah ok no worries, it must be only small / hard to find if its still getting some boost I guess? I was going to get some parts and a tune by Status so I assume Trent should be able to find it if I cant haha
edit: is there any common places to look?
Does your car have a front mount?
If so, the turbo > first hot pipe, is a common one on aftermarket kits. So is throttle body and first of the cold pipes.
Are you blowing any black smoke and is it idling rough?
Its just got the stock front mount
I will check pipes when I have a chance
It doesn't seem like its blowing to much black smoke if any, the rear of my car gets a little black but seems fairly normal black-ness to be honest.
It seems to idle a little rough sometimes but not at all times, and also seems after I turn the car off for say 5 minutes (get petrol or what ever) get back in and drive off it has trouble when it hits boost seems to missfire a bit? or at least seems like that and also will idle rough at this stage as well.
Used a oil filter removal chain, and then replaced filter with a socket type filter 'Drift' brand.
The only thing I saw near the filter was something going to the front diff? a wire or something from memory
under the inlet manifold there is a vineyard of black vacuum hoses. have a really good look, even use a mirror, its to coincidental that you changed the oil then this happened,
the reason i asked it you used a tool is this would make more sense if you pulled a hose off
yeah trent will be able to find it no problem in 10 mins or so. he would have fixed literally hundreds of skylines with the exact problem you describe.
Yeah i'll try and have a look when i can.. if not fixed I'm sure Trent will have no problems he would be 100x better with this sort of thing then myself :down: I'm more of a I.T guru rather then engine troubleshooting..
And yes! GTR has FMIC! ;)
Happy that its nothing serious
The map sensor for your gauge is located on the drivers side of the engine bay near your brake booster. There is a hose that goes from that to the back of the plenum near the firewall. The rubber tends to go hard, split/crack or just break off the brass pipe fitting that is on the back of the plenum.
You can easily reach it to check the hose. Give the hose a wiggle and squeese where it attached to the plenum. If its hard and cracked it will probably break off completely. Replacing the hose and doing a complete pressure test to identify other failing hoses is your best bet.
Well I feel like a idiot for not seeing this while changing the oil but here was the problem (simple boost gauge T-Piece rubber tube has busted):
Thanks for the help and advice people :ermm: gauge went from -2 ish to -20, and boosted 10psi plus now instead of dropping at like 6-7 psi and just not running well in general.
:D
  • 4 weeks later...
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
