Hi guys,
Just a quick question I'm sure:
Basically I've owned my R33 GTR for about 2 months now, I put some apexi pods filters on it and just has a cat back exhaust at the moment otherwise completely stock.
Now my boost gauge use to say -11 ish on idle and boost up to abou 10 PSI, (on both my mechanical boost gauge and stock gauge), and now after a oil change (duno if it could be related at all) sits at about -2 ish on the gauges and only found that its boosting up to about 6-7 PSI? and car just seems a little slower in general..
Now I'm no engine guru but my first thought was maybe there is a leak somewhere in my FMIC piping? but figure I'd just ask here to see if this has happened to anyone else.. sorry if its been answered before but couldn't find anything.
Thanks in advanced,
Leigh
https://www.sau.com.au/forums/topic/335130-rb26-noob-question-regarding-boost/
yep, most likely a pipe blown off, or vacuum hose off. best bit if you are not sure what to look for is take it to a mechanic and get them to find the missing/split/blown pipe. easy fix.
Ah ok no worries, it must be only small / hard to find if its still getting some boost I guess? I was going to get some parts and a tune by Status so I assume Trent should be able to find it if I cant haha
edit: is there any common places to look?
Does your car have a front mount?
If so, the turbo > first hot pipe, is a common one on aftermarket kits. So is throttle body and first of the cold pipes.
Are you blowing any black smoke and is it idling rough?
Its just got the stock front mount
I will check pipes when I have a chance
It doesn't seem like its blowing to much black smoke if any, the rear of my car gets a little black but seems fairly normal black-ness to be honest.
It seems to idle a little rough sometimes but not at all times, and also seems after I turn the car off for say 5 minutes (get petrol or what ever) get back in and drive off it has trouble when it hits boost seems to missfire a bit? or at least seems like that and also will idle rough at this stage as well.
Used a oil filter removal chain, and then replaced filter with a socket type filter 'Drift' brand.
The only thing I saw near the filter was something going to the front diff? a wire or something from memory
under the inlet manifold there is a vineyard of black vacuum hoses. have a really good look, even use a mirror, its to coincidental that you changed the oil then this happened,
the reason i asked it you used a tool is this would make more sense if you pulled a hose off
yeah trent will be able to find it no problem in 10 mins or so. he would have fixed literally hundreds of skylines with the exact problem you describe.
Yeah i'll try and have a look when i can.. if not fixed I'm sure Trent will have no problems he would be 100x better with this sort of thing then myself :down: I'm more of a I.T guru rather then engine troubleshooting..
And yes! GTR has FMIC! ;)
Happy that its nothing serious
The map sensor for your gauge is located on the drivers side of the engine bay near your brake booster. There is a hose that goes from that to the back of the plenum near the firewall. The rubber tends to go hard, split/crack or just break off the brass pipe fitting that is on the back of the plenum.
You can easily reach it to check the hose. Give the hose a wiggle and squeese where it attached to the plenum. If its hard and cracked it will probably break off completely. Replacing the hose and doing a complete pressure test to identify other failing hoses is your best bet.
Well I feel like a idiot for not seeing this while changing the oil but here was the problem (simple boost gauge T-Piece rubber tube has busted):
Thanks for the help and advice people :ermm: gauge went from -2 ish to -20, and boosted 10psi plus now instead of dropping at like 6-7 psi and just not running well in general.
:D
  • 4 weeks later...
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
