Hi guys,
I'm having problems while driving my r33 gtst.
when accalerating from 2,000rpms to about 4,000 im getting major lag but when i go to plant the foot it feels better.
its feeling like the turbo is really holding back and im getting nothing?
i have replaced my coils and they were a part of the problem but still having issues.
i can't remember the last tune it had and have an unknown history with the turbo?
p.s my car isnt reving out to the 7,800rpm?. im getting 5,700rpm maxx???
hhheeelllllppp.
thanks alex :(:D
did u use new coilpacks or 2nd handies? does it miss at idle at all?
pull the plugs back out and see what colour they are and if they are all evenly coloured. this will tell u if the problem is in 1 or more cylinders, if its only 1 then it might be injector, spark plug coilpack etc,
if its all then could be airflow meter or sensor etc
the coils were brand new super spark coils.
ill change the fuel filter cos it never been done and ill check the spark plugs.
yeah its shagged on idle, it always going between 700 and 1100.
it never wants to stall tho?
While it's idling, use a spray with alcohol (wd40, brake cleaner etc) around the throttle body/intake manifold.. if theres a leak the revs will react and climb momentarily
ill be straight with yas, i got an unknown history with the ecu to. i have an modifide intake plenum to, its the standard skyline intake but the plenum one front not the side, its like thery have just welded it up on the side and made the fitting on the front??
injectors i have no history on to?
hey,
i sprayed my manifold and interccoling piping with wd40 and no sudden change in revs??
also changed the fuel filter and still no change!!
on idle it sounds like its putting a deep sound and isnt holding rev crash hot.
its going up and down with the revs, from 900rpm to 1100rpm like it cant find its idle??
starting to get angry at it..
its got the same amount of power as a vn ss standard.. :D:ermm:
car only hits full boost after i think 4500rpm and is 5psi before that so it may seem like a sudden "kick" when on full boost, and it may be hitting r&r in the high rev renge due to boost leek if you have turbo back exhaust etc, hence the cutting out?
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
