Hi guys,
I'm having problems while driving my r33 gtst.
when accalerating from 2,000rpms to about 4,000 im getting major lag but when i go to plant the foot it feels better.
its feeling like the turbo is really holding back and im getting nothing?
i have replaced my coils and they were a part of the problem but still having issues.
i can't remember the last tune it had and have an unknown history with the turbo?
p.s my car isnt reving out to the 7,800rpm?. im getting 5,700rpm maxx???
hhheeelllllppp.
thanks alex :(:D
did u use new coilpacks or 2nd handies? does it miss at idle at all?
pull the plugs back out and see what colour they are and if they are all evenly coloured. this will tell u if the problem is in 1 or more cylinders, if its only 1 then it might be injector, spark plug coilpack etc,
if its all then could be airflow meter or sensor etc
the coils were brand new super spark coils.
ill change the fuel filter cos it never been done and ill check the spark plugs.
yeah its shagged on idle, it always going between 700 and 1100.
it never wants to stall tho?
While it's idling, use a spray with alcohol (wd40, brake cleaner etc) around the throttle body/intake manifold.. if theres a leak the revs will react and climb momentarily
ill be straight with yas, i got an unknown history with the ecu to. i have an modifide intake plenum to, its the standard skyline intake but the plenum one front not the side, its like thery have just welded it up on the side and made the fitting on the front??
injectors i have no history on to?
hey,
i sprayed my manifold and interccoling piping with wd40 and no sudden change in revs??
also changed the fuel filter and still no change!!
on idle it sounds like its putting a deep sound and isnt holding rev crash hot.
its going up and down with the revs, from 900rpm to 1100rpm like it cant find its idle??
starting to get angry at it..
its got the same amount of power as a vn ss standard.. :D:ermm:
car only hits full boost after i think 4500rpm and is 5psi before that so it may seem like a sudden "kick" when on full boost, and it may be hitting r&r in the high rev renge due to boost leek if you have turbo back exhaust etc, hence the cutting out?
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
