yeah ill take it to morwell tommorow and have it dyno'd so i can see what's wrong i guess.
i think ill try the fuel pump first then ill take it?
i really wanted to get the problem before taking it to get a dyno :nyaanyaa:
thanks for the help anyways and ill post whats wrong with it when i find out tommorrow.
Sounds like one of the many sensors is dead, the AAC is probably gunked up hence the bad idle and it probably needs a tune for the mods that have been done to it. All of these combined result in the issues you are seeing.
my oxy sensor is old and the plug has 3 wires going into it and one is just sitting in there.
the blue wire going into the oxy sensor looks damaged but would that be the reason?
whats the blue wire for?
cat converters are the most shitty things ever, iv bought 2 new ones in my life time and they cost about $150...
there only for the enviroment arnt they?
Actually they are a brilliant invention, without them we would have alarge amounts more smog and a large increase (im talking 20% of the pop) in asthma and breathign problems.
However if your cat is the original and 20 years old it is probably not doing anything anyway so no real harm with removing it.
    • Back on topic for you for a post Will it be on pump or ethanol? 2025 Spec RB build: G30 660 .83 would be good  artec manifold turbosmart 45mm external gate 1000cc Injectors Kelford cams 264 and springs Pistons and rods for insurance Oil pump with billet gears Headdrain and all good oil mods Quality intercooler 3.5 inch dump pipe to decent exhaust Link plugin Ecu or what ever your tuning is comforatble with Bolt on Trigger Kit - Nzwiring kit is go to ARP Headstuds Quality headgasket quality fuel pump- a TI/walbro 525lph PWM would be the go Quality fuel reg Will be over $15K AUD Enjoy the noise of rb on gate at over 7400rpm. Start looking for gearbox conversions if your hard on the gear. Now I've been there and done that with rb powered street car (2007-2022) much prefer newer stuff. Anything 90's Japanese is not a great experience these days and highly over rated. My 2015 Brz with a heap of suspension mods is such a better car even with out the power of my old s chassis' even on track. If wanting to play light chassis and decent power for a  giggle a k swap 86/brz would be the go Check my old build for engine stuff I really need to pay attention to post 2016 BMW stuff but seem all very heavy 1600+kg
    • I mean, the 240i is not a Supra... make it drop a few hundred kg, have a sportscar chassis, clearance for wheels etc... Maybe I want a hardtop Z40i XDrive or something :p I do agree with you though and have long said the B58 Supra/240i/340i/440i is the new R Chassis/JDM90's turbo rocket for mod lovers to ... not always appreciative response lol. Doesn't make it not true though.
    • I will do the build myself but I will be paying for the tune because I don't know how much about that and would rather it be done right and by a professional
    • Will you build and tune it yourself or do you need to pay for labour?
    • Mechanically that's essentially what the M240i is, it's just not pretending it's not a BMW
