hey guys
just wondering if you could help me out a bit as i recieved a traffic fine on my way home to melbourne about a month and a half ago.
the cop was fairly nice about it all and when i got home and actually looked at the ticket he hasnt signed it and also put the wrong address on the ticket.
as far as i know this makes it void as its a legal document and needs to be completed properly.
am i correct in thinking this?
thanks for your help guys
I got booked 7 yrs ago in my R33 GT-R doing 63 in a 50 zone.
Policeman put down the rego no. of the 1-tonner in front of me, instead of my plate (GTR33Z) & did a typo on my Lic no. too.
I fought it in court, citing a technicality. The policeman was there also.
Judge said, "So whilst the details were wrong, were you a driver that was pulled over?"
"What exactly is your number plate?"
"Hmm... was the car you're driving one of these Nissan GT-Rs then?"
After telling the truth, the magistrate said, "You're fine will still stand..."
The copper told me outside court that if I'd fibbed a couple of times, I would have got away with it.
I don't regret telling the truth though. At least I can lie straight in bed.
http://www.strangepolice.com/content/item/16799.html <- amusing, but unfortunately, a ticket is a ticket. rego + speed, irrespective of whatever else is on there is proof enough.
I love that story, i posted it on my FB, so good!
  • 1 month later...
My son here on SAU, just noticed a policeman taking pics of a car parked the wrong way on a thoroughfare.
I didn't know that you could be booked for that, until I looked up Rule #208(2)
Other ones to consider too are...
Rule #197 - Not to park on a nature strip
Rule #208 - Not to park within 3m of a median strip or double lines
State Gov't short of money?
Ahem...
Ahem...
Those fines have been around a long time. You can also be booked for running through puddles and wetting pedestrians.
And if the Gov't don't make money through people paying voluntary taxes, they'll make everyone pay them compulsorarily.(sp)
  • 3 weeks later...
\Policeman put down the rego no. of the 1-tonner in front of me, instead of my plate (GTR33Z) & did a typo on my Lic no. too.
you probably could have got away with just not paying it and the RTA would have been on a wild goose chase to figure out who to give the points too etc..
Hey! That used to be my plate! GTR33Z was on my midnight purple beast (B&W premium plates).
And believe it or not; but whilst driving that R33 GT-R with those plates once and then being pulled over for doing 60 in a 50 zone, the policeman also did a typo and wrote the wrong rego plate on the ticket. LOL
Those plates are publicity-shy perhaps??? :/
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
