Item Summary: R32 Gts-t Skyline part out
Condition: Used
Reason for Selling: Want something different
Asking Price: 1000000
Delivery Methods: PickUp
Contact Info: pm or Post
Extra Information:
Ok, im parting out a R32 gtst
Parts that will be avaliable are:
*Rolling shell, with stock suspension $2000
*RB20 engine package - motor (complete with all manifolds and stock 20 turbo)- box - exedy HD clutch - loom and stock ecu, $1200
*Genuine Trust cat-back exhaust $300
*Genuine Greddy Intercooler with piping $400
*Haltech E11V2 currently being used with RB20, have been told that its useable with 25 as is, i will check this with Haltech today. $1200
*SuperSpark coilpacks for RB20 and Series 1 RB25. $300
*Stainless highmount 20/25 turbo manifold, brand new never used, does not include gaskets, $150
All prices are slightly negotiable, but stupid offers will be ignored.
I will put pictures up tonight or tomorrow morning at the latest.
PM with any questions.
Started stripping today all parts will be out by the weekend. As parts come out, i will take photos.
https://www.sau.com.au/forums/topic/335198-r32-part-out/
Ok apparently i cant edit my posts on this site :S
But i have decided to strip the shell as i have had a lot of interest in separate parts at the moment it looks like this
The bonnet and boot lid have been sold. But a deal may still be reachable at a cheaper price.
Otherwise prices for the parts from the shell are as follows
*Front Guards $50 each
*Headlights $200 pair
*Indicators $50 each
*Front bar (stck Gtst item) $60
*Wing Mirrors $30 each
*Front seats $200 pair.
*Rear Seats $50
*Dash, no cracks all vents $200
*Rear 5 stud $400
*Tail lights $50 each
*Rear Bar $60
*Manual Conversion (box clutch pedal box etc, everything you need) $1000
*China turbo (same size as a kkr480) $200
*Door's minus window switches, including glass $150 each
*Window Switches $50 each
*Also have miscellaneous parts from the engine bay, make an offer.
If there is something you are chasing that isnt listed send me a PM and i will get back to you.
https://www.sau.com.au/forums/topic/335198-r32-part-out/#findComment-5431548
Im after the drivers front guard depending on the condition
please sms me on 0410665701 and I will come around and pick it up
Im on the gold coast myself
Edited by waxracing
https://www.sau.com.au/forums/topic/335198-r32-part-out/#findComment-5431604
  • 3 weeks later...
This is everything i have left need this stuff gone as its taking up room in the garage, so I'm open to reasonable offers.
*Haltech e11v2 suits rb20/25/26 $1000
*Rear shocks with lowered springs $50 pair.
*Rear reo $50
*Radiator and shroud $50
*Plastic side steps $40
*front rotors and calipers $200
*Steering rack (hicas) $50
*Engine crossmember $100
*Left Tie rod $40
*Interior light (the twin lights at the front of the cabin) $20
*Castor arms $50pr
*Camber arms $50pr
*LCA's $60pr
*Wiper motor $30
*Front seat belts $40 each
*Roof liner $40
*Rear Calipers $70 pair
*Cross over pipe with stock BOV $20
*Power steering res $20
*ignitor $50
*Climate control unit $50
*Switches from dash cluster surround $20 each
*Greddy Cooler kit $350
*Dash no cracks all vents $150
*Drivers side door (no window switch) $100
*dash and body loom $100
*ignitor loom $50
Edited by baffy
https://www.sau.com.au/forums/topic/335198-r32-part-out/#findComment-5477312
ok:
fuse cover in engine bay-> readable-> $?
battery hold down clamp -$?
A/C controller - $50 I'll pick it up as long as it lights up and works.
rear licence plate holder -$?
Front bar - condition - cut up or still stock. wnat stock with no damage.
https://www.sau.com.au/forums/topic/335198-r32-part-out/#findComment-5482998
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
