I'm really looking forward to it.
The new expansion is going back to basic story line of Vanilla WoW with the Black Dragonlfight paying a huge part part as well as Ragnaros and other characters.
At least dps won't matter as much in Cataclysm as it does in Wrath...crowd control will be important - no more "tank pull 5mobs and we will aoe them down".
Can't wait till it comes out :D
https://www.sau.com.au/forums/topic/335209-wow-cataclysm/#findComment-5432666
Is the date of December 7 confirmed officially by Blizzard?
I notice they have release the first of 3 (or 4, can't remember) patches, with the first patch being 4.5gb.
Obviously they are getting close to releasing it with the patches starting to appear now. What I can guarantee is that they will release Cataclysm before Diablo ;)
https://www.sau.com.au/forums/topic/335209-wow-cataclysm/#findComment-5482542
I bet you $40 it won't be pushed back haha.
There are a total of 3 4.5gb patches to download, and they obviously contain all the new designs and quests and bla bla bla for Azeroth etc. I guarantee it won't be pushed back :)
https://www.sau.com.au/forums/topic/335209-wow-cataclysm/#findComment-5492352
when its in my hands on the 7th, ill be convinced
https://www.sau.com.au/forums/topic/335209-wow-cataclysm/#findComment-5492376
I really want to play again but being married now etc (no... not under the thumb :) ) I don't really have spare hours that I can spend on it :(
Stopped playing Jan '09. Can't even remember my account details anymore.
divorce + wow = win
go to wow site and click the forgot username and password buttons!
https://www.sau.com.au/forums/topic/335209-wow-cataclysm/#findComment-5493433
Haven't played WoW since BC came out.. is there anything new and exciting and majorly different that warrants looking into this (and WoTLK :P )
not really, i rathered bc more than wotlk... i heard the new expansion is going to be more traditional!
https://www.sau.com.au/forums/topic/335209-wow-cataclysm/#findComment-5494726
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
