I played about 1 day worth of play time on my shaman once i hit 80 like 7-8months ago and saved up around 750 shards......
but im not sure how you buy the BOA items now from Wintergrasp? Is it with Justice points?
Well I'm off work from tomorrow until 22nd November for my knee reconstruction, so I shall be leveling my warlock heaps and playing COD Black Ops as of next week too :)
lol nice, i jelous, start a character on my server!
Level 30 already. So easy to level now. Mounts @ 20, instances are a breeze. Should have done this years ago haha.
Less grinding to get to end game, more stuff to do @ level cap.
i wouldnt be so sure, its only the recent patches that made everything easier!
once u get BOA gear its even quicker
Is it worth farming for points for BoA gear? I have like 0 J points on my main... My soon to be main is already 53... should i just level that instead
if ur 53 then yea no real point in trying to get boa gear from it, its really only beneficial from level 1
woooo my warlock is now level 52....and i have a play time of 1 day 11hours so far :P
and i still have another week off work :blush:
Maybe this is just my noobness talking but that is quite impressive especially for someone who doesnt have wow as an occupation.
I got hacked in Feb 09... account has been locked ever since, I was level 80 for a week.
I am in the process of attempting to recover my account to try the new expansion.
From what I have read up on, everything is so much easier now, kinda sucks, I liked it back when things were hard, not mount at lvl 20... etc etc
But I will still give it a go, pending I get my account back.
Anyone on Horde Dreadmaul?
Ive got a lvl80 Tauren warrior with all tier 10 armour, 20k crits are awesome. I also have a lvl80 undead DK but they are kinda boring so he doesnt have very good gear
I got from lvl 1 to 80 on my warrior with less than 7 days playing time.. and that was back in July/August. Im probably still considered a noob as i only started playing back in late June
Agreed with DK's being boring.
My Pally is 65. Not sure if I want to go ret pvp or holy pve @ 85. See how they both are I guess.
holy for pvp is really good atm on beta, ret is the worse spec for paladins at 85 for pvp
Arena season starts 1 week after Cataclysm is live and i need to level both my warrior and paladin, need grind x2 pvp gear set aswell >_<
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
