Normaly these brakes don't have a problem in pulling up
But the other day I was doing 110 or so and jumped on the brakes hard but she didn't pull up like she usually does, I had my foot pressed as hard as i could but the car woudnt come to a complete stop? The pads weren't hot or anything, i was normal driving before that..
So many options.
1. Boiled fluid at some stage, causing air in the lines?
2. Glazed discs?
3. Glazed rotors?
4. Does it have pads left?
5. Old fluid soaked with water?
6. Internally leaking master cylinder?
If it really didn't come to a complete stop as you said, well, get it checked ASAP!
You'll have to catch it first though.....
Is it still out there rolling along by itself somewhere?
Edited by Marlin
So many options.
2. Glazed discs?
3. Glazed rotors?
LULZ :)
So many options.
2. Glazed discs?
3. Glazed rotors?
7. Pistons seizing in the calipers.
True, but extremely uncommon on Sumitomo calipers.
Still check them though, especially if your car is showing any signs of corrosion, ie, it came from the snowy/salted area of Japland.
I haven't changed the fluid from when I imported it. That's another thing on the list. How can I tell if the discs are still any good?
Who imported it for you as it is a requirement according to the Motor Vehicle Standards Regulations 1989 for the all of the brake fluid to be changed, take it back and tell them to do there job correctly.
Edited by Guest
