hi everyone, can you help?? What mods to do first
i just purchased a close to stock r33 series 2 gtst, great condition in my opinion,
its got a 3 inch exhaust set up, pod filter, and aftermaket intercooler, super low king springs, and a blitz boost controller but not currently installed..
only stock boost settings,
would the best option to buy a power fc ecu, and get it retunned or would i be better to do something else first???
and if so, where can i locate cheap performance parts?? and i live in melbourne, whats the good tuning shops in melbourne??
https://www.sau.com.au/forums/topic/335261-rbb25dett-modifications/
cheap performance parts... LOL... first thing i would do is sell your skyline and buy something else.. cause you've bought the wrong car for that...
if not do some research cause there are wayyyy to many options for the little description you've supplied..
Real advice: Upgrade your brake & suspension system first as you need stopping & handling power before increasing performance
Edited by .:: GimpS-R34 ::.
    • And P R I C E. I love 98. 10kw loss 20% cheaper for a liter, 30+% more range per km, and available everywhere
    • That Fuji Dynamics sign is giving me Costco vibes
    • Yeah just google the part# on the AFMs, that will tell you what they are. The standard ones won't support over about 250-280kw so they have probably been changed. Not that it makes much difference unless you are planning on modifying it further, and in any case you would ditch the AFMs and move to a MAP sensor when you put a modern tunable ECU in.
    • Z32 AFMs are 80mm tubes. RB26 AFMs are smaller. Just measure. Nismo RB26 AFMs have a different part number to original 26 ones. Probably also have a Nismo badge - but I don't know because I've never been near one. It's unlikely that they've been changed anyway.
    • Hey looking for pointers or experiences with indicator wiring/ common faults for the blinkers on the r31, I have a 87 silhouette and am having dramas with the blinkers staying on (not flashing) to indicate right,while trying to indicate this way the relay makes a constant noise, The front passenger side fender blinker is missing the harness connector to the bulb so is not connected would this effect the opposite side? Both rears work as they should, and blinker that stays on functions normally when on hazards instead of indicating, have replaced all bulbs,fuses and relay Cheers
