im selling a 1998 nissan skyline r34 coupe 1998 gt model. (106756kms)
$3000 for the whole car dont have the cash nor time to fix it.
there are a few problems with the exterior as stated below
front bar which connect the front bumper was taken off due to being stuck in the sand an the tow truck accedinelty ripped of the front bar with the front bumper qouted at 4000 dollars from a panel beater but im sure if your a repairer you can repair it much cheaper.
the right blinker was ripped off but is easily repaired i have both blinkers but the right blinker just needs to be rewired which was qouted 100 dollars
back bumper needs to be replaced an the licence plate was pushed in abit but theres not much damaged there easily repaired.
needs new headlights on both sides qouted at 800 dollars.
theres only 1 default on the performance side an that is the transmission solarnoid just needs to be replaced which was qouted 800 dollars from power roads car sales in dandenong.
the car can be purchased if your willing to fix the problems an if your a repairer this would be a nice easy project for you to get the car back to perfect state or would absolutely be perfect if you looking for parts espeically with the performance side which there is only the solarnoid defect.
the car drives very well the power steering to the brakes to the engine all in great working order with no oil leaks and never had em.
mods:
tail lights are east bear l.e.d gtr lights
3 month old bridgestone tyranza tyres with stock nissan wheels.
sony mp3,wma, cd fm/am head unit with aux
electric sunroof
drift canon 4inch with 2.5inch pipe.
comes with top secret front bumper.
i live in victoria message me by email [email protected] or pm me thanks. mobile:0425497044.
(pictures attached)
Edited by 7on4r
https://www.sau.com.au/forums/topic/335282-for-sale-nissan-r34-gt-1998-damaged/
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
