Stock R33 Gtst For Sale Brissy Nthside
FOR SALE 1993 r33 gtst -$8k
stock as a rock under the bonnet
hks superdragger exhaust
17' mags 'euro concept'
manual turbo
150xxx k's
400r front bar (sh!t paint and cracked a lil)
other than that runs perfectly apart from the odd occasional "hunting issue"
mechanically neva missed a beat , great interior all original
will add pics when i figure it out ,
cheers
PM or call 0415657999 Paul
manual turbo
150xxx k's
cheers
Gday mate im on Northside too
can you PM me some pics
I will give you a call friday
Cheers
oh yeh it has a ceramic cushion button clutch 4 months old , new tyres like 4 weeks ago , uh the interior is perfect , drivers window switch is gay , on carsales
http://www.carsales.com.au/used-cars/priva...;PriceMax=10000,
:D
sorry guys cant reply to pm till i get my post count up so here's 1 less !!! haha but yeh check it out on carsales.com!!! its a good buy and i dont really wanna do it but its time to go , did i mention its got sunroof and i made the clock and climate controll thing blue and installed a switch to go from 'low boost mode ' to 'high boost mode' on the dash , works a treat !! uh other than that NO smoke AT ALL (gotsta be a good thing right ) no dramas with the gearbox, oh and what i mean by drivers window switch is gay is that its had the insides taken outta it and it just doesnt flick back when ya use it , window works perfectly , (i resoldered the joints in the box thingy) oh it had a new batt installed 7 months ago , interior is perfect - best i have ever seen in a 33 , i think thats it (for now ) ....
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
