try a 4 cyl forums. they usually jump the gun and buy the big housing and regret it later and want to swap.
I swapped mine with a guy who had a EVO.
hey all i have a gt 35/40 with a rear exhaust housing is A/R .63
i was wondering if anyone would be interested in swapping my housing for a .82 or 1.06 housing??
I can make you a .63 or larger housing to suit GT35 turbine wheel if you want. Can be either external or internal gated, with 6 bolt Nissan Dump, 3 inch V band or 5 bolt flange. Or get a Vl turbo or OP6 turbine housing we can machine it to fit.
I can make you a .63 housing to suit GT35 turbine wheel if you want. Can be either external or internal gated, with 6 bolt Nissan Dump, 3 inch V band or 5 bolt flange. Or get a Vl turbo or OP6 turbine housing we can machine it to fit.
Read the post properly...he wants a larger housing like a 0.82 or 1.06...
  • 1 month later...
  • 3 months later...
Short of the above, toymods forums also love the .63 AR on 35Rs. Maybe try put a for swap thread on that forum.
Those guys dont seem to have a problem running the small housings on JZ's the way we do on RB's.
