Yes the Stillen was a bit of a fight to line up, but we got it there in the end.
The lovely note it produces was worth the effort :dry:
I think i have a stainless dual output legallis Cat back for the v35 in the garage. Interested?
Prolly $1000 plus shipping from Melb, Vic ono.
Either that or I fit to mine to see how it goes.
I am not that fussed but thought worth a suggestion.
G
Hang on guys...don't bag stillen....it was bolt on!!! Took us 5 hrs to install as we were not familiar with the process but it took 2.5hrs to remove...
it was easy installing and easy uninstalling...don't know what went wrong with your install...
and yes, i would stick to the US aftermarket stuff...reason?? VERY SIMPLE.....there are more aftermarket parts for the V35 (G35) in the US than there are for the V35 in the JDM...The Nissan turbo fans never did really accept NA engines as a good platform and stuck to the RBs and SRs.....
So to sum it up, if you want to go aftermarket for your V35, go for Stillen....
Point of reference, my Nismo exhaust took 15mins to bolt on to my Stagea... including time taken to put the car up on the ramps.
Why so quick? Japanese "bolt on" is exact.
In comparison the Stillen took us about an hour and some not-so-subtle persuasion (large rubber mallet) to fit it in place.
Nothing at all went wrong with the install.
Yep, very true, The Yanks definitely have done more for the VQ35 than any any other nation and if you are going to build an engine, the US is where you turn... but for bits like exhaust, suspension etc you seriously can't go past the Japanese for quality, performance and fitment.
Edited by iamhe77
  • 7 months later...
  • 3 weeks later...
Installation of a twin rear muffler setup is not possible without modification and shielding of the fuel system, and removal of tow hook. Carbon canister and breather pipe will come in contact with the drivers side muffler. A local exhaust shop said it would take them a few days and over $1000 to do just mods and pipework (not including mufflers!!) from just the axle back (less than 2 metres of pipe total). Replacing the centre muffler and pipe was a whole lot more $$$ and time.
  • 1 year later...
Sorry to bring up an old thread but I'm currently looking at two catback systems that have been mentioned in this thread. The Stillen Gen 2 and the Fujitsubo Legalis R. I know that the Fuji is only a little louder than stock and the stillen is a fair bit louder but between the two which would give the most gains?
I don't expect to have gained 20kw from the system but between these two great pieces of steel which would the majority of other sedan owners prefer.
Also any idea on the pipe size of the Stillen, as I know the Fujitsubo is around 2.75"
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
