Hi All,
I just got my V36 Type SP sedan on the road a week and a half ago. Imported by Kristian @ Iron Chef Imports.
I was told by Kristian that this could possibly be the first V36 sedan in Adelaide, so I thought I'd post here and see if there were any other V36 sedan owners around!
Let me know if you have or know of someone with a V36 sedan here. I'd love to meet up and chat.
https://www.sau.com.au/forums/topic/335442-adelaide-v36-owners/
  • 4 years later...
2008 370GT SP Grade 4.5 with custom leather beige seats and wood grain interior. Thanks Geoff @ prestige around 27K Landed Complied and AORC
Saving up for turbo! 276hp (205kw) at the REAR wheels isn't enough :P
Edited by N3ptuNe
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
