I just had new camtech stage 1 cams 256 deg installed in my rb20 and it went from 190rwkw to 138rwkw
please help my tuner has no idea why? he has check the tune and time several times.
gt3540r, fmic, 1.2mm metal head gasket, plazmaman plenum, adj cam gears, sard fuel rail, regulator and 280l/h pump
not sure bout injectors but there not stock, apexi power fc, etc
https://www.sau.com.au/forums/topic/335455-massive-power-loss/
Both appropriate responses so far, but specs are still a bit sketchy including perhaps an overlay of before/after.
With that turbo (unknown turbine A/R?), and those cams (exact spec not really known?), and comments over the years from Roy about his RB20 exploits, you'd have to be thinking it wouldn't peak - with proper setup on everything - until somewhere well over 8000rpm. So besides seting cam timing, how fast was the engine spun during tuning?
I recall a couple of lads fitting a GT3582 sourced off an XR6T, onto a stock RB20. Pulled maximum power around 9000rpm, but I have no idea how long it ran like that...
i think in the op it already had the turbo on it, he just installed camtech cams and it lost power.
the obvious things to check, cam timing and if you put cam gears on it, try adjusting these,
check compression may also show if the cam timing is out of wack
The turbo was on the car when i purchased it and i think the A/R is .82
it had alot of lag before the cams where installed but it is even worse now.
it was running about 17psi at 190rwkw and is now 16psi at 138rwkw
my tuner recons he checked the cam timing and he adjusted the cam gears a few times
just to be sure.
Used alot of cammtech cams with no issues, in fact have never gone backwards once.
Your car has another issue, if it was making 190 rwkw @ 17psi with a GT3540R 0.82 before you changed cams it was already missing 80-100rwkw...... you could nearly make 190rwkw on a rb20 with a r34 std turbo....
you need to find the source.
i would throw a spare CAS on there, i have had 3 or 4 cars in the 10 odd years ive been screwing with nissans do the same weird thing, car runs perfect yet wont make power, swap out CAS and bang it makes 150 rwkw more. Doesnt make sense but it does happen ask ABU on here :P.
whatever is wrong its going to be something simple
to affect the power that drastic its going to be something simple
CAS mangled or unstable sounds bang on the money
ie at idle it checks out ok, but under load it might go spazzo
there were some cheap ebay cam gears going around with poor bolts
do u happen to have a cheap cam gear on it, have you checked the bolts
slipping gears would make it run like ass which is what you see on power
When a tuner like Trent offers you some advice like this I suggest you take it on board and actually try it. Do not know who your tuner is but you cannot argue with experience. If he thinks there is alot of missing power I am sure he would be willing to look outside the box... Right?
Ask your tuner to re-check your ignition timing... and when he is doing it take notice if he actually takes the "Nissan" coil pack cover off the engine or not...
Report back with the results, Please. If not.. Take it to Yavus at Unigroup Engineering. Problem solved.
I have spoken to my tuner about the CAS and he recons there is nothing wrong with it
he said he checked that it matched up with the what the power fc was telling him.
If it was the CAS would it still seem ok when it was tuned cause my tuner said it matches up
with what the power fc was reading. I have OS giken cam gears
Like Trent said. He has experienced carsrunnin fine but low on power and a simle swap of the crank angle sensor has gained alot of power
would not believe it i actually have an SAU'ers car on the dyno as we speak (rb20 in a cefiro) doing the same thing.
I will post up dyno graphs later. This has the CAS weirdness too. Car hits 190rwkw and nose dives back down....
Replaced CAS pulled 220rwkw on the first run with new CAS.
The only way to check it 100% is to actually strobe the ignition on the dyno (unsafe unless you know exactly what your doing)
Best bet is to swap out the cas with a known good one whilst on the dyno.
This car drove like normal, no stutters... no weirdness at all.... only felt weak up top.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
